Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
JD 7210 Draft arms will lift but not lower, no codes on dash
Can a hydraulic control sensor on a 7210 jd 3point hitch be cleaned or reset
Not sure what your asking, exactly what is it not or not doing
Feb 03, 2018 | Garden
Turntable arm will not lower - the guide just pushes it back to the off position
Try to do this
1. unplug the turntable
2. raise the arm
3. put it over the record
4. lower it which will not lower you said
5. push the arm to the very end close to the label
6. rotate the turntable by hand and it should take it through the whole return cycle of the arm and lower and finish the motion
7. then plug in and it should come back to normal
Dec 26, 2016 | Audio Players & Recorders
Issues with cold air draft in Chevy Silverado
Fresh air vent door is not closing,,, or blend door not working,,check elec or vac switches behind glove box for proper move ment,,, or if you have duel climate controls if could be defective ,,,not working on that side
Feb 20, 2015 | Chevrolet Silverado Cars & Trucks
My lift arms are in the full up position and will nor go down.
THAT MY FRIEND IS A STICKY VALVE. I had it with a crane carrier. Dirty oil or contaminated oil causes it, but you need to find the cause for water mixing with the oil resulting milkiness. maybe she was standing out in the rain with filler cap open?
Nov 15, 2014 | Cars & Trucks
How do I remove the spindles on a 1967 Chevrolet truck
You really should get a manual or look for one at the library so you can see the pictures. First remove the shock absorbers. Basically, you need to remove the balljoint tapers from the spindle, but you need a spreader tool to do it because they are very tight. You back off he nuts several turns. Don't take the nut off the spring can come flying out as the lower A arm falls. This can be very dangerous. Use the spreader to make sure both tapers are free. Then support the lower A arm with a hydraulic jack apply enough force to slightly lift that side of the truck. Now you can remove the nut on the top balljoint and lift the upper A arm up till the spindle is free. Then you can remove the bottom balljoint nut and lift up the spindle and remove it. Now you have to contend with all the spring pressure that is pushing down on the lower A arm. Tie some good rope or chain around several coils on the spring. and tie that to the frame so when you lower the A arm it doesn't come flying out. Often times it is best to use a spring compressor. You often will need one anyway to get the spring back in. Be very careful.
Oct 08, 2014 | Vehicle Parts & Accessories
How to lower the windshield arm ofn1999 mercedes benz e320
mercedes wiper arms can only be lifted a quarter way up , not at a 80 degrees , you must of bent the arm bracket or jammed it in sum way ,check the spring for tension.
Apr 09, 2013 | 1999 Mercedes-Benz E-Class
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
LIFT ARMS FOR 3 POINT HITCH WILL NOT MOVE, NOT SURE WHAT CONTROLS OPERATE
Standard tractors have a lever to the right of the driver, move toward the rear of the tractor to lower ... move toward the front to lift.
May 07, 2010 | Garden
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Ac problem
I just fixed mine. same problem, no ac light no fan. inside the heater control assembly there is a electric wiper arm on the fan switch. This arm connects all power for fan and ac. Mine broke out of the fan control switch. Dash is not too much problem to get out. Have to pull top dash center section out by puching forward and lifting out. pull all screws on center dash counsel. remove radio, two side covers that hide screwsand lower trim that holds emergency flasher switch. remove cables from heater control and wires and remove. Took me about an hour. The code on radio will need to be reset so make sure you have that handy. Hope this helps..
Jul 28, 2009 | 1998 Volkswagen Beetle
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
67 people viewed this question
Top John Deere Garden Experts
Dave
Jim Parker
Jim Parker
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
