Question about HP OfficeJet J4580 All-In-One Laser Printer
Printer is not printing ink on the paper. You can hear the cartiage dumping the ink and the head typing but no ink is comin out. And I just the balck and white cartiage to the Xl big cartiage. thanks, richard Joslin
  • 3 Answers
Try taking out the cartridge and wipe the lazer foil with white spirit then put it back in and try printing again
Posted on Nov 05, 2010
Prints 1" wide blue streak from top to bottom of page
If you're holding the paper so the narrow side is up, and the blue streak is vertical, then it's not a bad print head. If the stripe is from side to side with the paper held that way, then possible that the head is bad. The 4530 is an office type printer with large carts that connect to the print heads with hoses. It's possible that a hose has come off and is dumping ink that way, or that the hose is leaking...
Apr 17, 2015 | Epson Pro Wp-4530 All-in-1 Inkjet Wireless...
Can't print
Weather you use color or not the system is tied togeather to use them both. A laser printer however would have been the best choice for you if you did not want color. However weather you use color or not the printhead in this unit is daisy chained thus the printer will not start without the color cartridge due to print head damage that can be caused by a dry print head.
If both cartridges are empty its because you have used color at one point.
Thanks please do use the thumbs above to vote on this solution. Also please leave feedback
Feb 18, 2010 | HP PSC 750 All-In-One InkJet Printer
How do you remove printhead from kodak easyshare printer to install new one?
Hello my friend
First make sure that your print head is your problem before replace it
This is how you replace it
  1. If your printer is not powered on, press ON.
  2. Lift the printer access door and wait for the carriage to move to the access position.
  3. Remove any paper that may be loaded in the printer.
  4. Remove both ink cartridges and set them aside.
  5. Unlatch the used printhead.( Lift the button in the center)
  6. Lift the used print head out of the
  7. carriage.
  8. Take out the new print head from its bag
  9. Remove the 3 plastic protective shields.
  10. Place the print-head into the carriage.
  11. Push firmly against the back wall of the print-head until you hear a loud snap
  12. Insert the black ink cartridge into the print-head.
  13. Press down on the ink cartridge until you hear it click.
  14. Do the same for all inks
  15. Close the tray
  16. Lower the front access door and pull the paper tray all the way out.
  17. Insert a stack of 5-10 sheets of plain paper into the paper tray.
  18. For the Calibration:Press Start. Wait 2 to 3 minutes for the calibration sheet to print.
Jan 15, 2010 | Kodak ESP 5 Printer
Printing is blank...no ink coming out on to paper
Your printer cartiage will be out of ink.
Or it will be dry cause of not used from long time.
Change the printer cartiage may fix this problem.
Thanks.
Oct 09, 2009 | Office Equipment & Supplies
My printer will not print anything on paper. Brother MFC 4420C, Just brings the paper out blank. It has new cartiages.
if you filled the ink with some of the kits, the ink was not totally compatible with brother printer, and most likely dried inside. if that is not the case, do the cleaning from the brother menu screen for all ink cartridges. if you under warranty call brother. it might take a while to fix, since they may send a local tech to replace the head since that is mostlikely issue. if out of warranty, you best likey choice, curb it and get new one with extended warranty.
Jun 17, 2009 | Brother MFC 4420C All-In-One InkJet...
New Cartridge - Black showing no ink
u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
Nov 04, 2008 | HP Business Inkjet 1000 - Printer - colour...
My brother mfc 420cn printer won't print
i reset the printer to the original factory settings, and now it works. thanks for your concern and help, richard
Feb 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Paper jam
i have an hp office jet 5510 and its not print and it keep on saying cartiage is jam , the timeing is all mess up the leg that bring the paper out keep on coming up whilethe cartiage is going across is there a way of reset the print to get back the timeing
Nov 01, 2007 | HP Officejet 5510 All-In-One Thermal...
Balck ink not working
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Mar 16, 2007 | Canon S 330 InkJet Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
