Question about Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle
My spring is moving n my air rifle how do i fix it
  • 79 Answers
It is supposed to move.
Posted on Jan 08, 2011
Want to buy daisy air gun
Buy an Eagle OWL statue
Daisy Outdoor Products
www.daisy.com/ Manufacturer of airguns, ammunition and accessories.
Daisy Airguns - Daisy BB guns, Pellet Guns and Air Rifles from ...
www.pyramydair.com/m/Daisy/20 Daisy air rifles and Daisy BB guns are household names. Daisy started making airguns and BB guns as early as 1886. Daisy BB guns and air rifles have been ... ‎Daisy BB guns & pellet guns · ‎(steel and lead). · ‎Airgun pellets · ‎PCP & CO2 accs.
Daisy Air Rifles ' Airgun Depot
www.airgundepot.com/daisy-air-rifles.html Daisy air rifles are the face of what everyone believes an air rifle should be as a result of the fame created by the Daisy Red Ryder. Daisy is the oldest air r.
Daisy Air Rifles from D&L Airgun
https://www.dlairgun.com/Air-Rifles/Daisy/ Daisy Avanti Champion 499 - (DSY-AR-001). Daisy Avanti Champion 499. $189.99. Underlever spring piston .177 Caliber BB @ 240 FPS. More Information.
Daisy Model 25 Pump BB Air Rifle ' Cabela's Canada
www.cabelas.ca/product/23625/daisy-model-25-pump-bb-air-rifle Daisy Model 25 Pump BB Air Rifle. Created by legendary Daisy designer, Charles Lefever, in 1914. The modern Model 25 will take adults back to the excitement ...
Replica Fake Plastic Owl Decoys
Dec 20, 2016 | Cell Phones
How to fix air pump
The crossman phantom is a spring powered air rifle which means that you pull the barrel down through the arc of its travel until the piston locks up to the trigger mechanism in one continuous movement
Feb 08, 2016 | Crosman Optics
Is it possible to change the spring in this rifle?
almost certainly byt at a certain point a stronger spring means you have to have a fireams licence, (if we are talking about air rifles
Jun 25, 2015 | Optics
Cocking assembly
First establish a source for replacement parts, otherwise there is no point to mess with the air rifle.
Also by your description, I am not sure if the main spring is fully cocked or not at this point ?
If you are not sure about it continue cautiously.
Second (if you are mechanically inclined) start to take the rifle apart.
Remember that the danger is in the in the main powered spring.
Taking screws out is fairly safe, pins on the other hand should be done cautiously, they usually hold back some sort of force.
Pushing out any pins that hold assemblies together should be done with a smaller diameter pin than the one you attempting to push out. The pusher pin should go in loose, but if spring tension is present it will stick and keep things from exploding on you.
If the push pin gets stuck you will know there is spring tension that needs to be released.
Putting pressure on the right component or spot will free your pusher pin and allow you to release compression in a controlled and safe manor.
At this point you can just identify the parts that look broken or excessively worn and replace them.
Good Luck
Aug 24, 2013 | Umarex Air Ruger Air Hawk Air Rifle .177...
Replace main spring in RWS
hello friends you broke my rifle spring my rifle crosman optimus ea .177 cal. and the dealer put a new one, but it has presicion not know if I should wait for 500 shots or more like new or will be another problem, thanks for your help
Oct 08, 2012 | RWS Diana 34P air rifle - 0.177 Caliber
How to repair a ruger air hawk .177
well for starters, there is no firing pin, second, without major machinery, you can't fix a spring powered air rifle, any of them. It is impossible, major jigs and fixtures hold these things while the spring is removed and replaced. You might try crossman, they do a lot of repairs.
Jul 30, 2012 | Umarex Air Ruger Air Hawk Air Rifle .177...
How do i change my benjamin air rifle pump seal?
pyramidair.com has a seal kit. it also comes with a diagram. Benjamin and Sheridan air rifles do not have springs to propel the pellet. also never use vasalin. specifically for a Benjamin or Sheridan you need to use pelgun oil (also found at pyramideair.com). use pelgun oil because it is a non detergent fossil compound) the main intention is to condition the seals every 250 rounds. never use silicon based lube for this gun specifically. silicone lube is for spring air rifles such as break barrels.
Nov 23, 2010 | Dmm Benjamin Air Rifle
I Have a crossman .177 air rifle, that you have to pump, after the first pump you hear air leaking out of the barrell, how do you fix that?
Some air gun problems are an easy fix, some require extensive presses and jigs to move springs around. Most are not to messed with. I know, I have tried my best to repair an air rifle or two and had to send them back to the company to get them fixed. And there is nothing I can't fix, I have a big machine shop, been gun smithing for years and couldn't fix a little air rifle. Check out this website, it might help you, or steer you in the right direction. ,,,,,,,http://www.airguns.net/faq.php#faq1
Feb 17, 2010 | Crosman Optics
How can i get a new spring for a crosman quest model #c1k77x?
crossman customer service ph#1800 724 7486 start here they may
have it
Dec 13, 2008 | Crosman ® Quest cal. Air Rifle with 4x32...
Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle Logo
163 people viewed this question
Top Crosman Boating Experts
Ted Maxwell
Neil
Level 1 Expert
yobo007
yobo007
Are you a Crosman Boating Expert? Answer questions, earn points and help others
