Question about Toshiba Satellite A105 Notebook
Sound and video problems toshiba paas8-02000u
Hello my pc doesn t read disc in media player.no sound no image after upgrating the systems.
thanks for help[ing me.
I want to down load sound and vga drivers of toshiba pass8-0200u
Posted on Jun 19, 2008
Pls sir update the sound,modem driver
model no.satellite pro a120
Posted on Jun 18, 2008
My Bose dvd player is not reading the disc
Are you still need help? If so, how about giving another Free DVD/Blu-ray Player a try?
Leawo Free DVD/Blu-ray Player contains all media playback solutions you need for your leisure entertainment. It acts as free Blu-ray disc player, free DVD disc player, free CD player (video-CD), free HD video player (free 4K video player), free ISO file player, and free audio player (free music player). Being a free Blu-ray disc player software app, it plays Blu-ray discs for totally free, and downward compatible with DVD disc and CD discs playback, no matter they are commercial or regular. It's the best free software to play Blu-ray on Windows (including Windows Vista, XP, 7, 7, 8, 8.1, and 10).
Meanwhile, as free DVD player, it's not only a free DVD disc player, but also free DVD player to play back DVD folder and DVD ISO image file for totally free. It's also a free 4K video player to deliver extraordinary image and audio experience via 4K displays. It's cable of playing 4K video in MKV, MP4 and TS formats, 1080P videos in HD MP4, HD MKV, HD MOV, etc., 720P videos in MP4, AVI, MKV, and other formats, be it camcorder reordered footage, downloaded online video, or streamed video.
Hope it it anther choice for you an other users. :)
Best Free Blu ray Player Software for Windows Leawo Free Blu ray Player
Oct 30, 2016 | Bose Audio Players & Recorders
Dvd is too dark
b> Windows Media Player is a dynamic media player that comes included with Windows operating system.
According to the Microsoft website, Windows Media Player 12 plays nearly every video format, including 3GP, AAC, AVCHD, MPEG-4, WMV, WMA, and most AVI, DivX, MOV, and Xvid. So, before you begin, you may want to be sure you have the most up-to-date version.
Open the file in Windows Media Player. If it is not the default player on videos, simply right-click on the file, select "Open With" and choose Windows Media Player. Pause the video on a clear frame. Windows Media Player will begin playing the video automatically, so you just need to pause it on a frame that you think you will be able to use as a template for the rest of the movie. Access the Now Playing menu (this is in the upper left-hand corner). Click on it to pull down more options. Select "Video Settings" from the Enhancements submenu. This will open up a small panel at the bottom of the window with various image adjustment meters. Slide the "Brightness" control a little to the left to brighten the image. The image will stay the same until you press "Play," at which point you can view the effects of the new settings. Repeat Step 5 until you find the right brightness. Close the Video Settings menu by pressing the red "X" in the upper right-hand corner of the menu screen.
http://windows.microsoft.com/en-US/windows7/products/features/windows-media-player-12 b> Brightening the video may give the image a bit of a "washed out" look. Remedy this by tinkering with some of the other settings in the menu. Increasing the Saturation often helps with this problem.
b>
Feb 09, 2013 | Computers & Internet
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Can't read discs
Is power getting to the drive? Will the tray open and light blink when closing the drive?
If so, it sounds like the lens may be dirty. There are several things you can try: Gently blow into the open drive, use a vacuum, purchase a lens cleaner.
Sep 06, 2009 | Toshiba Satellite A135-S2386 Notebook
Play dvd nothing - play s/d card (video) sound but no picture.
You need to update the dvd softwear. Check the default settings for playback of media,if it is set to windows media it won't work if you hav'nt installed the correct updates. Choose the Toshiba dvd player as the default player and it should work. If you prefer windows media then you can get the updated codecs from ' free-codecs.com ' Easier still,try uninstalling your windows media player and installing windows media 11, this will usually resolve the problem.
Oct 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
DVD read problem
Hello. It seems for a software problem. Try installing newer codecs, or install a video player. Try this.Its a video player that neds no codecs installed http://kmplayer.en.softonic.com/download
Apr 30, 2008 | Toshiba Satellite M45-S165 Notebook
Toshiba satellite ps141e 181g1w en 256ram 2ghz celeron wont play commercial dvds
Hello tango13
(01) Which partition(s) is/are FAT32?
(02) Which partition(s) is/are NTFS?
(03) Do you mean your OS partition is FAT32?
A Microsoft Windows OS on FAT32 cannot "see" NTFS partitions. Conversely though, it can see FAT32 and NTFS partitions if the Microsoft OS partition is NTFS.
(04) If your OS is on a FAT32 partition, you need to convert it to NTFS if it is to be able to "see" other NTFS (and FAT32) partitions.
(05) If I didn't understnd you correctly, please, in detail, explain the problem again and tell us what the file system is on each of the partitions you refer to.
(06) What did you install from Toshiba OEM discs?
(07) Do you mean that, after performing one reinstall of WinXP Home that you then used the Toshiba System Restore CDs to restore the system again? (effectively wiping out the 1st reinstall of Windows XP you said you performed)?
(08) What precipitated your reinstalling your OS in the 1st place? (I ask because the reason(s) may be connected to the issues you are currently experiencing.)
(09) Your media player and codec issues are not related to your file system issue(s).
(10) How many **DIFFERENT** commercially-produced DVDs have you attempted to play in your laptop's DVD ROM drive?
(11) The DVD ROM drive spinning and not being able to read your DVDs is either (1) a media compatibility issue or (2) the media is dirty or damaged, or (3) a mechanical issue w/ your DVD ROM drive. In any case, I seriously doubt if it is a software issue. IOW, I believe it is a hardware issue.
(12) Make sure of the following:
(A) The movies you are attempting to play are actually on DVD media and not Blue Ray or some other media type that is incompatible w/ your optical drive (DVD ROM drive).
(B) The media (discs) are clean and not scratched, warped or otherwise damaged.
Please, post back here w/ answers to these questions along w/ any more questions, observations, or comments you might have. Let us know also what else you've tried in attempts to correct the issues you're experiencing.
Thank you
BJ @:)
***IMPORTANT NOTE***
Once you assign ratings to the experts' contributions, the problem will be automatically closed and we'll no longer be able to assist you. So, please, wait until your problem has been resolved - *then* rate the solutions and choose a "Best Solution". As long as the problem remains open, we will be able to continue to work w/ you on it.
Apr 15, 2008 | Computers & Internet
Toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
Nov 12, 2007 | Sony VAIO GRZ660 Notebook
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Toshiba Satellite A105 Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
