Question about GE (PSS26MSRSS) Side by Side Refrigerator
My refrige dont run just hums when you plug it in, fan in bottom wont run as well lights on in fridge how do i chek compresser
  • 4,070 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem and you'll need a tech to check it out to see if it's low on freon or worn out.
Posted on Nov 05, 2010
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
My refrigerator and freezer are not properly cooling. The lights are on, but everything in the freezer has thawed and the stuff in the fridge seems to be getting warmer.
Could be several different things. Try to listen if the compressor is running or humming. Check to see if the evaporator fan is operating (behind the back wall) The evaporator coil could be frozen solid preventing air to flow through coil. If this is the case, either your defrost heater is broken or the fan is broken.
Jul 15, 2010 | Whirlpool GS5SHAXN Side by Side...
Humming noise from a 10 year old General Electric Refrigeator
Does it still get cold (means is the compressor still working) ? Find the tubes on the outside of the fridge bottom or back. They should be hot when running, if not you have serious trouble. If the humming is coming from the compressor and it is not running (cold coils) the compressor may be very hot then the compressor is shot and so is the fridge (due to cost.)
Jun 08, 2010 | GE Refrigerators
My GE refrigerator GDS18LBPWW with freezer on bottom does not cool in the refrig. section. Yesterday, I pd $239 to have the Evaporator Fan motor replaced. The freezer is fine and back down to 26, but the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The ideal temp for the freezer is around 10 degrees F.
Look at the evaporator coils behind the rear cover inside the freezer and check the ice forming on the coils.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM
Dec 29, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Gsl25jfpa bs fridge is warm on top and frozen on bottom and freezer is warm
It sounds like the fan in the freezer is not working , to circulate air , and the coldness is just dropping . This will cause the icemaker to stop working first , then the top portion of the refrig next . As this coldness drops , the lower portion of the fridge ( crispers ) , will freeze . The main control board , causes the fan , not to run . Part Number WR55X10656 . The main control board , is located , behind the refrig , behind an 8 " X 10 " , small panel . There is usually a burnt resistor on the board , which is connected to the fan . Unfortunantly , the whole board will need to be replaced . It is easily replaceable . Doesn't take any special knowledge . All the plugs 6 or 7 , each fit the pin plug designed for it .
Oct 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
My kenmore side by side/ model 55771/ is having the same problem.
Is the fan running by the compressor and are your coils clean under refrig ? also make sure the cardboard panel is on the back of the refrig .
Jul 22, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
