Question about Maytag Dishwasher
I have a Maytag dishwasher, model #MDB4100AQ. Is it possible to replace the door panel on this dishwasher? I see the relevant part number (99002109) in various online parts stores, but before I order it I want to make sure this is a do-it-yourself job. I can't see any screws or other hardware that's holding the panel in place.
    Champion:
  • 246 Answers
You may not have to deal with the screws. Check out ApplianceArt.com to see if they might have a solution to fit your needs. I know they have stainlesss options, but also colors and designs.
Posted on Jan 07, 2011
Does maytag dishwasher model MD9100AWB have a interchangeable color front?
you model number is missing a letter I'm guessing its a MDB9100awb. They don't make them like they use to, where you can just flip them around nor you have to order a whole new front.
For White Order 99001416 For Bsq Order 99002109
For Stainless Steel Order 99002169 For Blk 99001417
they look to be around 75 buck
Oct 12, 2014 | Maytag Door Reversal Kit - Universal for...
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Jul 24, 2013 | Fisher and Paykel Dishwashers
Maytag MDB7601AWW door will not latch
possibly need a new door latch assembly this is kind common on those maytags the latch assembly becomes defective or doesnt latch properly...W10130694 is the part number for the replacement part u would need you can see a pic of this part at repairclinic.com just enter the part number. you could purchase it there or online thorugh sears or etc... also check local they might stock at and be cheaper with no frieght shipping charges......to change this or check your assembly prob have to remove all screws from inside door usually a torx bit this will seperate panels and control will pop off.. hope this helps
Feb 06, 2010 | Maytag 24 in. MDB7601A Free-Standing...
Lose of functions
more than likely this is a control board issue
either from a small leak in the soap dispensor
or steam from the vent
you can get a replacement part for about 109 dollars
and with the part number AP4114872
at appliance parts pro one word dot com
but if it works id leave it alone
Oct 02, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Wont start after iinstalled a door switch
on the inside of control panel there is a fuse located on the side of the control board replace the fuse. for a detailed parts list you can go to www.searspartsdirect.com enter your model number
Sep 22, 2009 | Maytag MDB5100A Dishwasher
My Maytag Jetclean Dishwasher Model # MDB4010AWB Serial # 16163916uk is stoping midcycle, it doesnt make any noise or anything just stops. Water left sitting in bottom and have to open door then close...
possibly a bad door switch losing contact, only after opening nad closing is it making contact again. part number for door swtiches and holder 99002254 retails for a about $25
Nov 05, 2008 | Maytag Dishwashers
Neff Dishwasher
Telephone BSH 08705 543210 ask for spares department who are very good helping you with spares as long as you have all relevant serial and product numbers it can sometimes be difficult to get through because they are always busy, be persistent
Aug 19, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Maytag Dishwasher Logo
71 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
