Question about Logitech X-240 Computer Speakers
Hi, My Logitech Speakers are connected to my laptop as they always have been. However, the left speaker will not sound, I have checked all the wiring, nothing. What else can I do?
Then there is something wrong inside the subwoofer
Posted on Nov 05, 2010
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
Logitech z-2300 subwoofer not working
ahh logitech always the sub that goes. its buggered but dont toss out the whole speaker set just buy another one and youl have spare speakers when you need them
Jul 28, 2010 | Logitech Z-2300 Computer Speakers
Speakers not working when reconnected to pc
How do I get hold of the necessary graphics driver?
Apr 18, 2010 | Logitech X-540 Computer Speakers
I purchased a new desktop PC with Windows 7, & I'm trying to find out what the correct connection is for the Logitech X-530 Speakers is. That is, can I get all the 5 speakers to work at the same time?
It depends on the sound-card in the PC.
The "back-left" and "back-right" speakers require special connections to the sound-card.
The "left" and "right" and "centre" speakers are connected to the "main-stereo-audio-out" on the sound-card, as per normal.
Apr 03, 2010 | Logitech X-530 Computer Speakers
How can I connect my logitech x-230 speakers to my new laptop with windows 7? Never had probs before
Windows 7 adds High Definition and other sound features. Sound can be selecting in many more ways and it gets even tricker with microphones.
But this should do it:
Left Click "Start"
type "control panel" enter or click on menu selection
Left click "Sounds"
Enable your speakers from the default settings
Mar 27, 2010 | Logitech X-230 Computer Speakers
I have just bought the logitech x-540 speakers and have found that they have 3 input cables (one for each of the left, right and centre speakers). However my laptop only has 2 input 'holes'. The...
Hi bud , What your laptop has is a 2.1 Channel Sound card , and your speakers are a 5.1 Channel Surround Sound system ...So in order to get the Real pure surround sound , Sound out of the speakers you will need to buy a 5.1 Channel Sound card...
Hope you come right bud
happy new year :)
Jan 06, 2010 | Logitech X-540 Computer Speakers
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
Left speaker sometines has no sound? Please help
I bought a set of Bose companion 3 speakers and the darn RCA jacks are cheap and wiggling loose. The cost to send back and repair out of warranty is about $125!! BOSE companion speakers may sound good, but for my money, I'd rather go with more reliable computer speaker systems like Creative or Logitech. BOSE IS WAY TO OVER-RATED, but HEY....they suckered ME out of $275!!!
Feb 06, 2008 | Bose Companion III Computer Speakers
Both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Dec 26, 2007 | Logitech Z-540 Speaker
Logitech X-240 Computer Speakers Logo
37 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
