Question about Goldstar R5208 Air Conditioner
Problem with the thermostat?
My air conditioned runs for about an hour and then it shuts off while the fan is running for about 5-10 minutes and then it comes back on for 5-10 minutes...if it is the thermostat switch, how can I fix it?
  • 1 more comment
  • Brognan Jun 15, 2008
    When I turn it down it just turns off, I have it on max at the moment, and there was a wire that wasn't connected to the radiator behind the filter, I pushed it back where it seemed to belong and it worked for quite a while until I turned it off, Then it started doing the on-off thing again. I will try to lessen the temperature a bit and see if it helps
    It's just a little window unit Goldstar R5208, since turning down the dial for the thermostat didn't help too much...thats probably the problem...it is an old machine atleast 5 years old...Guess I'd have to take it to someone to put refrigerant in it, thanks for the help
  • usbus May 11, 2010
    What is the temperature you have it set on? Perhaps setting a lower temp setting might help lessen the trigger on the thermostat...
    Novelist:
    Champion:
  • 230 Answers
I am not sure what kind of air conditioner this is, but it is possible that it is low on refrigerant. This would cause the line to begin to freeze. When the line starts to frost over the anti freeze protection will shut the compressor off until the frost goes away. Then the compressor will turn back on and begin the same cycle until the refrigerant levels are corrected.
Posted on Jun 15, 2008
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Dv209aew/xaa therm
u may have a bad motor windings problem, usually will rund for about 25 minutes to an hour then shut off, wait an hour and can run again then shuts off ? also check ur venting inside machine and to the wall a build up can cause it to overheat and then shut down? u may have to remove cabinet to see inside condition? which thermostats did u change, u may have bad hi-lo limit and cycleling thermostat
Jul 28, 2014 | Samsung Dryers
Why is the fan only running on low speed?
Hi David. when the air conditioning is energised by the thermostat it should automaticly bump up to high fan speed, if it has been running for a while it ciould be freezing up the evaporator and causing a restricted air flow to come out. you may need to shut the cooling mode off and just leave the fan running for a few hours. hope this helps
Jun 03, 2014 | Dometic Rooftop RV Air Conditioner
I had a Honeywell Thermostat RTH8500 installed by a pro to run Heat / Cool electric heating WITH central air conditioning. Problem : When running on cool Fan on auto ,it work OK but sometimes when the...
Is this a new hvac system? A new furnace can work differently than your old one. Does it shut off after a minute or two or continue to run? If it continues to run then call that professional back and let him fix it. If it shuts down after a minute or two then it is a feature of the new thermostat to squeeze all of the cool it can from the a/c coil and ductwork.Some of them have settings that you can adjust for blower delay on and off, read the manual that came with the t-stat and see if it does.
Jun 16, 2011 | Honeywell Heating & Cooling
Ac problem
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Feb 06, 2010 | Heating & Cooling
FAN STAYS ON LONG (HOURS) AFTER COOLING TEMP IS ACHIEVED
There is a built in delay on all HVAC systems to evacuate conditioned air (hot or cold) from the ducts -- it's just more efficient that way... but if it's staying on for more that 4-5 minutes at most then there may be a problem with the fan relay... or possibly a limit switch.
Sep 02, 2009 | Heating & Cooling
I have a DuoTherm unit on my 1989 Cross Country that only runs in the "low" position and shuts off after about 5 minutes. Won't come back on until about an hour later, then runs for 5 minutes or so...HELP!
Is the unit ducted with a wall mount thermostat? If so, then I would say that you need to check the thermostat. Remove the face plate from the thermostat, there should be 6 or 7 wires, depending on the model. With the thermostat set to high/cool, check for power at the yellow wire and the blue wire. Yellow is the compressor terminal and blue is the high fan. If you have no power at the blue terminal, then you have a bad thermostat. If there is power there, then you need to access the control unit in the air conditioner (remove inner shroud). Check for power at the blue wire at the control unit. If there is power, then you have a bad control unit. The unit is shutting down because it is freezing up in the low fan speed position. You can use a jumper wire on the thermostat to go from the +12 terminal (red wire) to the Hi Fan terminal (blue wire) and also the fan terminal (Either tan or orange, depending on the model). If the fan comes on, then you have a bad thermostat. If not, then you have a bad control unit or the high speed in the fan motor is out.
Hope this helps,
Jeff
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Fan keeps running.
Some programmable thermostats have a circulate feature. This feature will allow your fan to run approx. 20 minutes per hour. This will insure better circulation, a better balanced temperature throughout the home & better air quality do to more air filtration. Read your thermostat manual to see if your thermostat has this feature and how to turn it off if needed. Another possibility would be on an older furnace with a fan limit control. If the temperature settings are set to low on the fan limit (or if the control is malfunctioning) you could experience a fan that runs a lot even if the thermostat is off.
Apr 10, 2009 | Honeywell Electronic Programmable...
Central air
Most thermostats have a setting for the fan called, "manual". That keeps the fan on continuously. The electronic thermostats can fail in a "fan on" condition. That would require a new thermostat. I also saw one air conditioner with a fan relay welded "on" by electrical surge. That would require a new relay.
Jul 20, 2008 | LG LWHD1800R Wall/Window Air Conditioner
Goldstar R5208 Air Conditioner Logo
281 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
