Question about Kenmore 63942 Dryer
Kenmore 80 series dryer
Dryer was running but no heat changed heating element ,it woks puts out heat but now the dryer wants to come on without hitting the start button and the motor wont start and makes a humming noise
  • Anonymous Mar 29, 2014
    Start up issues
  • 481 Answers
Humming noise usually means a bad motor. how much did you disconnect when changing element?
Posted on Jun 28, 2008
I replaced the element in my 80 series dryer. Now the element continues to heat without the dryer running ! Any ideas?
Some were u got what call short to ground. It problem the motor are u got a wire touch the dryer cabin if u don't know how to check it u might won't call for service are when u put the element back in it case one of element heating coil is touching the case.
Apr 03, 2015 | Dryers
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Heat does not stay on
Check the high limit thermostat. You can check it using a multimeter or ohmmeter. If bad, replace it. Hope this helped.
Jul 18, 2009 | Kenmore 800 7983 Dryer
Kenmore 80 series runs but dont blow hot air
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
Feb 12, 2009 | Kenmore Dryers
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
80 series front load dryer will not turn.
It almost has to be the belt as the heating element won't come on without the motor turning.
Jun 26, 2008 | Kenmore 62802 Electric Dryer
Kenmore 63942 Dryer Logo
182 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
