Question about Hoover Vacuums
It has been cleaned , yet there is no suction the hoover wont pick hardly anything up & it gets hot very quickly
    President:
  • 1,673 Answers
Then there most be a clog either in the hose or the dirt inlet by the brush roll. If you pull the hose off like you are going to use an attachment, is there suction there. If not, then the problem is in the hose. If there is suction, then the problem is down below,
Posted on Jun 17, 2008
My Hoover Windtunnel Model U6618-900 doesn't have enough suction to pick up anything?
Make sure you canister is empty. The interior air filter is clean. Check if the hose is free of any debris.
Dec 22, 2016 | Hoover Vacuums
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Have a hoover model F5914-900 it wont spray anything out the hose attachment. The line isn't clogged any ideas?
Yes, one thing to try: With the hose attached, place your hand over the suction opening at the pick-up end of the hose. Then pull the trigger. The pump is suction driven, and if there is air in the water line in the hose, that is known to allow th hose to prime in about 10 to 15 seconds.
Mar 09, 2010 | Hoover SteamVac F5914-900 SpinScrub...
No suction
I have found more vacuums on the way to the dump because they were full. Check. Is it full?
If not the air way is clogged.
May 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction in carpet cleaning mode with Empower
Check the nozzle . Turn it over on it's belly and remove the 4 screws that hold the base plate on. Take off the plate and remove the brushroll. I bet you will see a clog in the intake. If not take it to your local vac shop and let them fix it.
May 28, 2017 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Vac wont pull/**** anything while we try to vac floor,
Hello RonD30,
If you are getting suction thru the hose and not from the bottom section.. you have a clog somewhere inline with the base area... If you have access to a shop vac ... unplug the Hoover, open up the base and remove the beater bar /belt assembly.. then hold the shop vac nozzle on the point of entry to where the Hoover pulls the debris into the dirt compartment. I am fairly certain you have a clog somewhere in that ducting.. Stubborn ones may need a little motivation.. so you may be able to get an electricians snake or metal coat hanger bent to release the jam..
Hope that helps..
Regards,
Rick..
And you are right , regarding Lowes..but don't exclude Home Depot from the same rating..LOL Once the sale is done.. so are they...
Dec 13, 2008 | Hoover Vacuums
Suction hose
i would first double check the hose, remove it and drop a marble through it to be sure. make sure the bag is new and also check the filter underneath the bag if it is clogged it could cut the suction.
Sep 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Problem suckin up water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41079&thid=729141
Problem sucking up water
Pos Problem sucking up water
Ted by raybrower on Jul 01, 2008
Have a Hoover SteamVac with 5 brushes and it will not suck up any water and I have cleaned all the brushes but it still wont pick up any water
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Part of the problem is with your holding tank, there is a rubber gasket that seals the unit to pup the water and if that gasket is cracked or missing it will not pup. Also there could be something wrong with the suction motor or the Hoover SteamVac may be clogged and will not pup the water, if there is a way to say back track the suction then follow the suction back to the suction motor and if you see a clog – remove it. Otherwise you may have a bad suction motor and it would need replacing as a last resort. If the Hoover SteamVac is less than one year factory warranty it would be covered under the Hoover factory warranty and then feel free to contact the local Hoover Factory Authorized Dealer in your area, so call the cust serv @ Hoover and they can direct you to a dealer that would cover this under warranty. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover agility wont suck
There are 2 filters and if either one gets clogged, it will not suck up the water. One is from the bottom, it is red, pull it out far enough to clean it. The other one is behind the dirty water tank, remove the tank and you can see it on the wall covering the inlet for the suction. Clean it off, you should have suction now.
Feb 13, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
U5397-900 - wont clean carpet
could be, but probably just needs a new belt - they stretch.
Dec 16, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
98 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
