Question about U-Line CO2175F
There is a small plastic bracket that holds the top of the small door in the refrigerator. it is held to the compartment by two 1/16" plastic pins molded into the part, whose size is 1/2 x 5/8 x 5/8". one pin has broken off, and i need a replacement part.
  • joeredding Nov 07, 2010
    The solution offered was for the freezer door with pins attached to it, What i need is the small bracked (top and bottom) that holds the pin on the freezer door. part size 1/2 x 5/8 x 58 with two protuding pins about 1/16 dia.that go into the metal freezer compartment.
  • joeredding Nov 12, 2010
    I hoped you could have the part number. I already had the U-Line customer
  • 643 Answers
U-Line Customer Care Call Center can be reached by calling 1-800-779-2547, you can order the parts you need from here
Posted on Nov 11, 2010
  • 476 Answers
Hello, If this part visible from the outside with the refrigerator door closed, then you need a hinge assembly, if you are referring to a door inside the unit(door open) then you need the freezer door which has a couple of plastic pins formed to it and are actually a part of the door. There is a website that you can use as a reference to look at actual pictures of some parts that are available for this model. Try the www.repairclinic.com, type in your model in the search window and you will get a list of parts, prices and pictures of some of the parts that are available. It might be that you will need to special order what you want. Thanks
Posted on Nov 06, 2010
Will not make ice
I have a Samsung RF265AABP model. I had the same problem on several occasions. One time the problem was a broken temperature sensor wire on the ice maker. The sensor assembly often gets snagged on the ice tray or scoop or something and falls down, making it more likely to snag, and prevents the ice maker from cycling when frozen. It is quite easy to remove the ice maker once you get the drawer removed from the slides. It is held in place by two plastic clips located near the back of the slides. Pop the clips out, and then lift the drawer out. Pull the front plastic cover off the ice maker, then remove the two screws holding it to the top of the freezer compartment. Slide the icemaker assembly forward about 1/2 inch and it will drop down. Unplug the wiring connector and the ice maker assembly will drop right out. The temperature sensor is located in a flexible rubber like unit that holds the sensor against the plastic water tray. This whole assembly often falls out, and may be found mixed in with the ice.
I fabricated an aluminum bracket from angle stock to hold the temperature sensor assembly in place, and used a small tie wrap to hold the wire to the bracket, up and out of the way after soldering the broken wire of course. The tie wrap is not shown in the photos below. I drilled and countersunk two holes for the 4-40 screws holding the aluminum bracket. The temperature sensor is not shown in the photo, but the wire comes out the right side and crosses over to the left in front of the aluminum bracket.
Aluminum bracket holding sensor in place.
Ice maker assembly showing screws holding it to freezer. It is upside down in this photo.
Sep 23, 2013 | Samsung RS2630SH Side by Side Refrigerator
Ice maker stopped making ice
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. Check your digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
After fixing this problem several times, I finally made a metal bracket from aluminum angle, drilled and tapped 4-40 holes in it, and drilled the plastic icemaker to mount it more permanently. I added a wire tie to hold the temperature sensor wire up and away from possible snag sources. The sensor wire and wire tie are not shown in the photo below, but if you have the tools to solder the wires and fabricate a bracket it helps a lot. It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
Ice maker assembly upside down on bench.
Aluminum bracket and screws
Bracket installed. The sensor is not shown in this photo, but the wire comes out the right side and crosses in front of the metal bracket. The wire tie holds it to the bracket near the top center (hole not shown).
Sep 15, 2013 | Samsung RF263AERS (258 cu ft) Bottom...
Icemaker stopped
Sep 13, 2013 | Samsung Refrigerators
Ice maker not making Ice.
z
2q==
z
Aug 18, 2013 | Samsung RS2630WW Side by Side Refrigerator
Model RS267TDWP/XA. Not making ice
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. On my model RF265AABP, I check the digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
z
2q==
z
Aug 11, 2013 | Samsung RF265AA Bottom Freezer French Door...
Removing doors off
remove the top plastic cover that hides the freezer bracket. Remove the screws that hold it on. pick the door up off the bottom bracket. if it has a water dis unhook hose. do the same to the fridge door
Apr 01, 2012 | GE GSS25LGM Side by Side Refrigerator
How do you change the direction of the door opening.
(THIS IS A TWO PERSON JOB)(be sure u unload the door first)At the top of the door u have a bracket with three screws or bolts in it, take out the screws while the other person holds the door once this is done take off top bracket the door should lift off of the bottom bracket,now take the bracket off the bottom of the refrigerator,On the other side of the fridge there should be some small white plastic plugs pull them out ,this is were u will put the bottom bracket ,u will also have some plugs on the top of the fridge too..be sure u put the plugs back in the holes that u just took the screws out of.Put the bottom bracket on first,do not over tighten screws,then take ur door place the bottom of door on bottom bracket,put bracket for top of door in the top and screw back down now ur door should be good make sure it closes correctly,and of course put the stuff back in the fridge
Mar 31, 2011 | Refrigerators
A rubber piece fellout and there is a white wire hanging out.
This just happened to me.
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Mar 02, 2010 | Samsung RF265AA Bottom Freezer French Door...
Samsung RB215 -How do you remove the bracket that holds the door
The Cover hinge is misaligned, causing a no cool situation, the door switch and magnet are out of alignment, the door alarm is also on
The Blue arrow shows the hinge improperly aligned, the Yellow arrow shows the correct position of the hinge
f8ccb64.jpg Solution: Using pliers adjust the height of the hinge by pushing it down, the cover hinge will align properly as well as the door switch and the magnet, energizing cooling fan and
having refrigerator cooling properly.
Jul 27, 2009 | Refrigerators
U-Line CO2175F Logo
66 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
