Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
MyBook -Not booting up
When I start up my notebook, the MyBook powers on then it sounds like it is skipping (trying to boot up), then it stops and the notebook nor PC will recognize it. Please advise.
  • 4 more comments
  • Staci777 Jun 17, 2008
  • abnjr Jun 17, 2008
    My external HD (Mybook) does not get recognized in "My Computer" it is recognized in Remove safe utility.
  • Anonymous Jun 17, 2008
    i have the same problem, it just sounds like its booting up , then skips , and never is recognized in my powerbook
  • eddiemaster Jun 21, 2008
    I have the same hard drive, and after a year of usage, it just started doing the skipping and not recognizing thing last night. I have had another external hard drive that did the same thing in the end, and it could not be fixed, nor could the data be recovered...
  • Anonymous Jul 22, 2008
    Hi. I pretty much have the same problem with the drive not booting up. I plug in the USB and the light comes on and Windows starts to load up the files but then it shuts down (light goes off and drive disappears from My Computer), then it starts to boot up again with the light coming on and it's like it just goes through a power cycle. I have a SERIOUS amount of music that I have for DJing purposes and I'm pretty much screwed and am not looking forward to buying another drive.
  • Anonymous May 23, 2009
    My MyBook 500 Premium boots up. Doesn't make weird noises.
    The rotating blue button light goes on for a while, and while still starting up Windows XP, the light just goes off and never turns on again.
    When I press the button in the front of it, it doesn't turn on.
    When I unhook the drive from power, reinsert power, the drive seem to start up, but never is recognized during the session.
    After reboot, the same issue keeps on repeating itself.
Fixed by turning off USB legacy support in BIOS
Posted on Jul 10, 2009
Mim2300 not booting from cd
hi Graham.
it would be best to go and look at this link and it will be better for you to be shown step by step on what to try to get it sorted.
HP Notebook PCs Cannot Start Notebook Computer From Bootable CD or DVD HP...
or you could also try this link and there is lots of forums you can go into to see if it helps you out a bit more.
Mim2300 laptop not booting from cd Google Search
Nov 20, 2017 | Computers & Internet
Dell Inspiron 1545 will not boot up.
Try removing battery and booting on AC power only from adaptor
Then take out ram modules and reseat these, try to boot
Disconnect hard drive, DVD rom drive and try to boot.
If you get a beep sound, this shows that at least there is power to the system. Note down the number of beeps and post the result.
Feb 10, 2010 | Dell Inspiron 1545 Notebook
Laptop will not load windows vista from bios mode. I have tried recovery discs but still NG, from start up goes past bios & then stops as Vista is starting.
have you tried a system restore and then booting up? I had an issue booting up with vista and tapping Alt+F10 during BIOS fixed, it seems to skip the corrupted part of the boot.
Feb 08, 2010 | Toshiba Satellite A300-0CF035 Notebook
When I plug in my WD MYBOOK ESSENTIAL 1 T Drive the XP machine will not boot. It locks up during boot but if the WD drive is unplugged the boot process continues. After booting plugging the WD Drive back...
This is normal, simply because when your system is performing the boot sequence when it is first powered up, it checks all the possible drives that has an operating system on it according to the way it is configured to start checking it from the BIOS.
So possibly the default selected place for it to check first is the external drive, and since there is no operating system on it, it gets locked up and it might show NTLDR Missing...or Disk Error.
What you can do to stop that is :
When your system is booting go to setup, and depending on your BIOS type, try to locate where the boot sequence starts checking for Operating System from, if it is removable drives, then just change it to Hard Drive. Then save and restart.
Hope this helps you out.
Goodluck
Nov 17, 2009 | Western Digital My Book Essential Edition...
Vista 64 - slow boot with WD MyBook attached
This is caused if there are any system files on your external drives OR if you have set the bios to be able to boot from usb devices
One or the other is where you need to look.
Aug 17, 2009 | Western Digital 320GB MyBook External USB...
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Nc6000 will not boot
Sounds like your O/S is corrupt. Can you get to setup? Make sure your hard drive is in the correct boot order.
Jan 13, 2009 | HP Compaq nc6000 Notebook
My HP DV1000 will not start.
You have a power issue. The board is not charging the system or the battery. If you know someone with a similar model, ask them if you can borrow their battery and see if your system boots with it. If it does, you may need a new adapter or the power board in the notebook is out. When you remove the battery and try it, there's enough juice to power it up for the moment, but not sustain it.
Nov 19, 2008 | HP Pavilion dv1000 Notebook
MyBook 500GB Home Ed hangs WinXP SP2 boot up process
Thanks to Guest above. I was having the issue with USB of my WD drives causing the system to hang upon boot up. Disabling USB Legacy did the trick. It's only my WD externals that were causing me the issue but no mor
Jan 24, 2008 | Western Digital My Book Essential Edition...
Mybook failure, now failing as internal
Dude you can still read the drive in Windows. The drive is formatted in Fat16. The partition you are talking about is only to get the USB to recognize the FAT16. Just a boot loader for the device. The problem is the voltage regulator. They are only using a 1 amp that should be a 2 amp. The harddrive has some current draw. When the drive starts flashing it just overloaded the power supply and cant be read by Windows. Simply remove the drive plug it in a IDE interface on the computer and you should be ready to go. You could also replace the voltage regulator with a higher current model, but you must be an expert in soldering SMT......
Jan 04, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
831 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
