Question about NetGear WGR614 Wireless Router
Forgotten my wpa code as im trying to link up to xbox live.
  • 3 Answers
Log onto your router and get the pass key.
1. go to 192.168.1.254 in your web browser2. login to your router - try admin/admin or admin no password3. look for the SSID key - should be a security tab4. enter that in your xbox for the pass key
Posted on Nov 05, 2010
My sons xbox password was forgotten and now he cant add any of his friends what do i do
Are you talking about the manual passcode that you assign on each console? Or the password to his XBox Live account?
_________________________________________________________________________
What do I do if I forget my pass code for my Xbox LIVE Account? If you have forgotten your Xbox LIVE account pass code, recover your account using Xbox LIVE.
    To recover a gamertag
    To recover your gamertag, you need the associated Windows Live ID and password for your Xbox LIVE account.
  1. If you're signed into Xbox LIVE with another gamertag, press the Guide button, and then press X on your controller to sign out.
  3. Press the Guide button again, and select Recover Gamertag.
  5. Select Recover Gamertag again.
  6. Enter your Windows Live ID and password for the gamer profile that you want to recover.
  7. Follow the on-screen directions.
__________________________________________________________________________
What do I do if I forget my password for my Xbox LIVE Account? I recommend you follow these detailed instructions if you have forgotten your actual Xbox Live password. Good Luck. http://hubpages.com/hub/Forgot-Xbox-Live-Password-Recover-Password-or-Gamertag
Jul 16, 2011 | Microsoft Xbox 360 Console
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
A couple of years ago i made my xbox live account and accidentally set the family settings to high now that im using my xbox agian i cant really do anything on live since i dont remember my password or...
spacer.gifReset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Oct 16, 2010 | Video Game Consoles & Games
Wpa numberwedont know
to get your wpa key you will need to go into your router usually 196.128.0.1 and it will be in there if you are on verizon look on the bottom of the modem
Mar 28, 2010 | Microsoft Xbox 360 Console
Im writing to you about and inapropreate problem with my xbox super elite console im triing to set-up my 12 months online code so im follwoing the instructions so ive gone to market place tso rede code but...
You are able to redeem Xbox LIVE codes using the Redeem Code page on the Xbox LIVE website. Simply log in to your Xbox LIVE account using your LIVE email address and enter the code in the page.
If you're asked for address or billing information, fill that out first; you only need to do it once.
Mar 21, 2010 | Microsoft Xbox 360 Console
How do i get web code for my wireless internet
The wep code is the security code for your wireless network. this is setting of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
Feb 11, 2010 | Actiontec Qwest Wireless USB Network...
How do i find my wpa code im trying to connect to xbox live
hey !
It is very simple to find the WPA key. That is the security password for the wireless network.
Click Here for more info about how to find the WPA key
Oct 11, 2009 | Computers & Internet
How do I turn find my WPA password
It sounds like you are running through a router. The password will be from the router and not xbox live. If you know the password to access the internet from your pc through the router .. it will be the same for your xbox live.
CK
Aug 02, 2009 | Computers & Internet
Prolem with xbox
well if it IS working, you wouldn't be here would you? XD
anyways go to the wireless settings and manually add your SSID and WEP/WPA if applicable. If this doesn't work, get back to me.
Jul 31, 2008 | Microsoft Xbox 360 Console
NetGear WGR614 Wireless Router Logo
134 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
