Question about Philips Televison & Video
I bought a Philips 32PFL3605 a couple of months ago. Was working fine until last couple of days. Now the white on screen appears pink - this is gradually getting worse. Any idea what is causing this?
  • Philips Master
  • 5,159 Answers
This is likely a sign of a failing backlight. However when you open up the TV, check the inverter that runs the backlight since that is easier to replace and check. Open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Nov 05, 2010
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
Touch screen not working?
well wen you dropped it did the ink move luiek the colours where were wrong for example the white was pink etc.. if this has happened ,and it is common in touch screen phones, the phone is no longer good you can still keep it if you want but the problems will get worse n worse until its just gone
Aug 09, 2009 | LG Dare VX9700 Cell Phone
Pink and Black in natural light
It sounds like the light sensor on the camera is malfunctioning. Try cleaning the sensor. If the senor doesn't work at all it will not be able to tell when the camera is operationg in bright light. Kind of like having your eyes dialated and walking outside on a sunny day.
Jun 15, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Looking for this part from Panasonic CD or DVD player: PPN13KA12C
Is your Lexus 2/3 generation Navigation system not working? Famous 'No disk detected' message?
I was lucky a month ago and got a used one motor. Repaired my DVD and the GPS works fine. Then I wanted to buy couple more motors in case my wife's Navi goes bad and to have some spare ones. I bet I was searching under both PPN13KA12C and PPN-13KA12C (proper designation) for over a month every day, couple of times a day, and nothing, until today. Google PPN-13KA12C and go to SMC Electronics - CD and DVD Repair Parts to buy them for $6.50 plus shipping. Hurry, they won't last.
Apr 03, 2009 | 2002 Lexus RX 300
HP 190 Cartridge cleaning not lasting
You should apply to service. The Fault is caused by wear-out rakel knife. This device which clean the photo a drum.
Mar 25, 2009 | HP 190 Copier
Canon PowerShot S400 Screen Problem
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Apr 28, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
A White Screen!
I had the same problem a few months ago. Best bet is take it to get it fixed. If you still have a warrantey it won't cost you a thing. Good luck!
Feb 29, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Televison & Video Logo
705 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
