Question about Ruud Matching Split Air Conditioner
Manual for installing rudd thermostat for Rudd 41-20804-16
5 Suggested Answers
  • 659 Answers
SOURCE: Rudd furnace
You have a safety limit switch that is either bad or needs to be manually reset. Some have little buttons between the two wires going to the switch that you can push to reset. If not they are automatic switchs then one is bad. You have to do an ohms test to see if each switch is bad or good.
Posted on Jan 05, 2009
  • 10 Answers
SOURCE: rudd gas pack schematic
Email me and I can send you the schematick
Richard (Rick) Drennan
Global HVAC Distributors
Field Support Representative / Instructor
rdrennan@globalhvac.com
900 Spreckels Ave
Manteca, Ca. 95336
Office (877)448-7263
Cell (209)456-0513
farfield
  • 462 Answers
SOURCE: Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to rep
A new unit will be 13+ seer unless you can find someone that has replaced a compressor or has one left over from pre 2006 stock. Our wise Government with all its resources decided that we aren't smart enough to turn off the lights to save energy, so they chose to end the med and low price lines. And the same bunch of smart ones decided that now R22 because of its chlorien content being bad for the air (5% of what R12 was) so we have R410A and others that no one knows how much cancer or daMAGE THEY WILL DO OVER TIME. So now if you replace your AC unit out side with a new one be sure its compatable with the refrigerant inside and beware soem manufacturers wont stand up to full warranty if you dont buy an indoor coil and rerplace it too.
We get what we deserve in Washington DC and if our guy didnt support this stuf too many other folks guys did. We just dont talk about it enough. AND WE SHOULD. But then again you like me are probably RITCH. So we have to give up our wealth to the government so they can redistribute it and buy more votes. And we can stay working too much to talk about it.
Just burns my back side like a 4 foot flame.
Read tween the politics and you'll get my recomendation.
Buy your self a compressor and get someone qualified to install it or see if the old goodman one will interchange easily.
Posted on May 12, 2009
jmgldsmth
  • 1889 Answers
SOURCE: RUDD UPKA-061-JAZ Specs:
Ruud Air Conditioning Division • P.O. Box 17010
Fort Smith, AR 72917-7010 • 479-648-4900
Posted on Jun 13, 2009
Rudd furnace pilot wont stay
You have one of three things here
1. Dirty pilot, needs to be cleaned.
2. Bad thermocouple needs to be changed and pilot assembly cleaned.
3. Bad gas valve pilot solenoid call a repairman
Nov 09, 2014 | Heating & Cooling
Rudd furnace pilot wont stay lit
Have your local gas compreplace your thermocouple.
Nov 09, 2014 | Plumbing
RUDD Model UBHC-21J18SFA: Emergency heat not automatically engaging. Used to work, now I must manually turn the thermostat to "Emergency Heat" to get the elements to engage. What's broken?
Sounds like your Auxillary heat is out (the element that is energized when an air to air heat pump can't keep up with the thermostat setpoints).
Jan 30, 2014 | Heating & Cooling
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
Schematic diagram Rudd silouette II a/c gas furnace needed
There should be a small set of screw lugs on the electronic board in the furnace. Look for a red wire that comes out of the transformer and follow it to find where the 24V connections are.
Sep 21, 2009 | Ruud UBHC Air Conditioner
How to power on a rudd air conditioner without the remote
you sure 12000 BTU that small for split? if it is split system then it turn on off by the thermostat
Jul 10, 2009 | Heating & Cooling
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
HI! I have a Rudd Power vent hot water tank Model PVP50-1 how do a change the tempature setting? Thanks~
on the bottom of the tank there is usually a removable plate behind the plate is a thermostat your manual should explain where to set it
Jan 04, 2009 | Heating & Cooling
Rudd furnace
Jan 02, 2009 | Ruud UBHC Air Conditioner
Ruud Matching Split Air Conditioner Logo
459 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
