Question about Stanley Bostitch Rn45b1 Industrial Coil Roofing Nailer
RN45B secquentail trip will not work; contract trip will work only when slam hard on work. I do not know what to replace. small air leak .Can you help?
    President:
  • Stanley Master
  • 1,388 Answers
Remove roll pin holding trigger. Examine trigger for wear. A loose/ worn trigger can cause problem that you describe. Also examine the roll pin that holds trigger, if it is worn where trigger rides replace pin. If trigger and roll pin look ok then problem most likely tva6 valve. This valve has a pin that wears out. Order from ebay for under $20.00. If the gun leaks air, remove head and clean orings in the headvalve. Pull cylinder and clean orings to cylinder seal. Remove fine scratches on body of gun where orings contact metal. Use 400 grit paper. Lube all orings with silicone paste (sold at lowes in the plumbing department for faucet orings). To remove tva6 valve remove two pins in body of gun and apply air pressure to pop out valve. Use glove when you catch tva6. Use caution because the valve can come out with force (lower pressure ). Good luck
Posted on Nov 08, 2010
96 Blazer has a rust hole in the lower filler pipe. Code for evap is tripped. Also getting egr, O2 sensor on 2nd bank and Cat. codes. There also is a tare in the air supply hose from the filter to...
P0442 small leak
The evaporative leak detection diagnostic strategy is based on applying a vacuum to the EVAP system and monitoring the vacuum decay. The VCM monitors vacuum level via the fuel tank vacuum sensor input. At an appropriate time, the EVAP purge solenoid and the EVAP vent solenoid are turned ON, allowing the engine vacuum to draw a small vacuum on the entire evaporative emission system. After the desired vacuum level has been achieved, the EVAP purge solenoid turns OFF, sealing the system. A leak is detected by monitoring for a decrease in the vacuum level over a given time period with all other variables remaining constant. A small leak in the system will cause DTC P0442 to be set. This DTC is a Type A DTC
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
Clogged exhaust port .
Nov 08, 2017 | Cars & Trucks
Air leaks around green cylinder at trigger area and nail plunger will not retract. this is a stanley bostich rn45b nailer
Your nailer uses a trigger valve (part # tva6 cost about $20) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good holidays.
Dec 02, 2010 | Stanley Bostitch Rn45b1 Industrial Coil...
Will sometimes trip breaker when starting
Your compressor may not be unloading completely. Check for leak at intank check valve. Follow the airline from pump to tank. Remove the airline from he brass valve, with air in the tank spray soapy water to check for leak, replace as needed. If no leak the examing the pressure switch where 1/4 tubing connects. There you will find a small lever that opens a stem to unload air from airline. You can test the function by running the pump then switching off at the pressure switch, listen for release of air. If works ok then not enough power is reaching the compressor. Use very little or no cord and do not overload plug with other tools.
Nov 02, 2010 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
2008 Nissan Maxium keeps losing air in tires as soon as it gets cold
air contracts in colder air temps and is normal that tires could be a little lower but should be fine when you start driving as the air heats up..if its just one tire check for a leak or something in the tire(small screw, nail) that would cause air to leak out in the cold temps. if all tires are doing that check valve stems and tighten them with valve stem tool available at any auto parts store. If tires were replaced they might not have replaced the valve stems and that could be it too.
Nov 01, 2010 | 2007 Nissan Maxima 3.5 Sl Sedan
Looking operators manual for stanley bostitch rn45b
Look here for manual and parts:http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=WM45B&serialNum=
The two lines of address above should be all one line in the address bar. If it does not work, go to www.bostitch.com , service parts and find wm45b. Good luck
Sep 18, 2010 | Stanley Pneu Roof Stapler
Our Whirpool Gas water heater is leaking from one of the top water supply lines and the pilot went out. we tried to light it back on and it does not. before we can replace the leak should we continue to...
first repair the leak then remove the burner assembaly at the end of the pilot tube you will find a small orfice were the gas comes out for the pilot remove that and be sure it is free from debri and not clogged replace it when the burner assembaly is back in place and reconnected try to light the pilot if it still wont light as you are trying to light the pilot tap the side of the gas control valve (somewhat hard) if it then lights you know you have a bad gas valve if you are getting gas through the pilot orfice (not air if you have recently disconected the gas supply) and it seems to be blowing to hard you will need to replace the pilot assembaly at the end of the orfice as the small sheild also helps make the gas air mixture
Aug 25, 2010 | Whirlpool Heating & Cooling
Losing power 98 TJ wrangler
Sounds as if converter on exhaust is getting plugged up. have it checked and replaced. That will force exhaust out ahead of it where ordinarily it would flow with less pressure. Oil leak is a separate item.
Jun 28, 2009 | 1992 Jeep Cherokee Sport
Replacing oil levl sensor due to oil leak.Is it urgent?
If the leak is small. just a couple of drops no problems.just check your oil level when u stop to get gas
Mar 08, 2009 | 1999 Mercedes-Benz E-Class
Hard shifting 1999 Malibu
Some things to look for for would be a vacuum leak still in the intake manifold gaskets (that's a tricky gasket), check the MAP sensor since if the connector is loose or if it's leaking or defective it might be the cause and even the TPS, although you'd think a MAP or TPS problem would trip the MIL. I've seen wires get twisted up, broken and misrouted between the back of the engine and the firewall that could cause faulty information going to the PCM. Good luck.
Feb 06, 2009 | 1988 Chevrolet Silverado 2500
Stanley Bostitch Rn45b1 Industrial Coil Roofing Nailer Logo
152 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
