Question about Denon AVR-1908
How do I connect it to a video projector for a projection screen???
I have a panasonic projector, and I have attache the (3) RGB cables to the video out on the reviever and to the video in on the projector. I get the channel sound out of the reviever but do not get the video picture??
I can not get the DVD video as well?
  • 71 Answers
This sounds like a connection problem - have you got hold of the right leads and are they properly IN the correct places?
Posted on Jun 14, 2008
How to adjust the screen size on a projector tv
mismatching resolution is the problem. If you have a DVI input on your tv I would buy the conversion cable to go from RGB (off the back of the cable box) to the DVI. You should have an RGB on the TV as well and can go RGB TO RGB. Many possibilities including using a scan converter.
Feb 15, 2015 | Panasonic PT-53WX52 53" Rear Projection...
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
I use OPTOMA ex 532 with windows 7 32 os the projector working properly but in pc screen not displayed the projection screen
You have three option to view projection screen on your PC SCREEN:
1. Use "Y" cable to connect the projector and pc screen at a time.
2. Use "Video Splitter" to connect projector and pc screen at a time.
3. you can use a VGA cable to connect your pc screen with your projector VGA OUTPUT. here I show you the pictures.good_help_4.jpggood_help_5.jpggood_help_6.jpg
Jan 20, 2011 | Office Equipment & Supplies
Panasonic PT LB50NTU - LCD projector need to connect to my IMAC - what cord do I need?
The Panasonic projector PT-LB50NTU or E have two type of data inputs.
One is RGB or VGA cable and second is VIDEO cable. If your IMAC have video or vga output than you can connect.
Two type of cables witch are using with projector good_help_0.jpggood_help_1.jpg
Jan 14, 2011 | Panasonic PT-LB50U Multimedia Projector
I have two Panasonic PT-LB10VU projectors doing the same thing. They project find with RGB, but when trying to project a VHS tape through video, the image rolls or has multiple lines running through it. ...
first of all you replace the present video driver VHS tape and try any other dvd driver or any other video device if problem exist then the main board of you projector is faulty.
Solution: open the upper over remove 5 screw back side of projector.
disconnect the panel ribbon cable.Remove lamp cover with 3 screw remove main board with 4 screw and 8 connector. put it face down on a table and use a table lamp for more light.
check very carefully the area I show in the picture with red arrow there is a resistor no.R041(on resistor 750) is burn out or black replace witch 75ohm resistor and check around the resistor if burn any other component replace with the same after repair of main board fix the all part of projector as you open. Power on and use any video device other than your VHS tape maybe the high voltage comes on video output.
Dec 20, 2010 | Panasonic PT-LB10VU Multimedia Projector
Iamge from the previous projection from RGB still appears when i switch to Video mode. why is it?
Hi There
Looks like your Projector's Mainboard has locked the memory and is stuck.
If you can access the Projector's Menu - Reset the machine and switch it off.
If the problem still occurs , you will have to take your Projector to a Service Centre to have to Mainboard repaired.
This is 100% NOT a lamp issue.
Apr 18, 2008 | Hitachi (DT00431) Projector Lamp for...
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Denon AVR-1908 Logo
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
