Question about HP OfficeJet 6110 All-In-One InkJet Printer
Will not print and keeps saying remove and check carttridge.
  • 613 Answers
Make sure if it is new cartridge that you took protective film off of copper contact side.. If you did clean the contacts with a pencil eraser.
Posted on Nov 05, 2010
My hp 2600n colour printer display open door, my yellow carttridge is bad pouring ink can this be the course of displaying open door ,can i remove the catridge ?,will i be able to print without it
you can't print without a missing cartridge.
there might be something stuck or the hook that's holding the front cover is loose or broken. try to check for something there. or you may consult a technician for that. thanks.
May 04, 2011 | HP Color LaserJet 2600n Printer
I have put in the carttridge but it says 'the cartridge is missing'what must i do now? P.S: it is a original cartridge
try cleaning the contacts in your printer, the one where you put your cartridge. if that doesn't work, try printing with one cartridge, in this case, the color. if it starts printing, something's wrong with that new cartridge. if not, then your printer is dead :(
Jan 29, 2010 | Lexmark Z735 InkJet Printer
Replaced lexmark carttridge for printer problem
here you go the instructions out of the user guide this should help
Aligning the print cartridges
Load plain paper.
2 Open the Solution Center.
3 From the Maintenance tab, click Align to fix blurry edges.
Maintaining the printer
52
Click Print.
The alignment page prints.
5 Open the top cover of the printer.
6 Place the printed alignment page facedown on the scanner glass in the lower right corner, and then close the
top cover.
1 2
7
Press .
After a few seconds, an Alignment Success dialog appears on your computer screen.
8 Click Close.
9 Click Exit.
If you aligned the cartridges to improve print quality, print y
Oct 23, 2009 | Lexmark X2500 All-In-One Printer
Black line down middle of page
Clean the inside of the printer with a soft rag, be gentle and get as much toner up as you can, also your toner carttridge may be empty or the crum may be bad, start with a fresh toner carttridge and clean the printer out where the cartridge sits.
Dec 13, 2008 | Brother MFC-7820N Laser Printer
Carttridge is slamming against side of printer, light is flashing, no printing, no paper jam
I suspect the problem for both of you is either the blockage of the position sensing path (a slot in the carriage) or the plastic band that is imprinted with many vertical stripes and lets the printer know where it is and needs to go is not where it belongs.
Open the printer as you would to change cartridges and look carefully with a flashlight inside for a thin ~ 6mm (~1/4") plastic strip and insure that it is clean and stretched between both ends. One end is normally anchored to the chassis, the other attached to a spring suspension.
Nov 05, 2008 | HP D1560 Deskjet Printer InkJet
HP OfficeJet V40 Won't Print
You Need to change the Ink Carttridge. it has either Dried from lack of use or you have run ou tof ink.
you may need to clean the Jets as well a simple Q-tip with some rubing alchol would work.
You could also try the Printers Cleaning Utility, but either way you'll need to replace the cartridges
Andres
Apr 28, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Printer wont print anything black
hmmm..even on test page, eh? maybe you need a new set of drivers(they get corruped easily).
Mar 09, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Cartridge Stalled Error
Sounds like some muck on the guide bar or perhaps a bit of paper getting in the way ..
Nov 06, 2007 | Dell Inkjet 720 Printer
WILL NOT PRINT
cartridge must be damaged and need to replace
Oct 21, 2007 | HP Deskjet 5940 Photo InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
