Question about KitchenAid KEBC208 Electric Double Oven
I have a Kitchen Aid KEBC208KSS04 and the lower oven was in cleaning mode and the power went out. When the power came back on the oven finished cleaning but I cannot get it to work now. Is there a reset switch or breaker that needs to be reset some where on the oven?
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
  • 833 Answers
SOURCE: self cleaning
Sometimes, according to what I've seen.  My theory is that the elements are probably covered in grime and this causes the damage.  As far as the control...I don't think that makes sense.
Never use cleaner on the elements..also causes damage.
A typical duty cycle for cleaning is 2- 2.5 hours.  Longer and you could burn them up, too.
Posted on Nov 28, 2008
localwonder
  • 6784 Answers
SOURCE: kebs208d THE DOOR WILL NOT UNLOCK
HI, this is a major control fault. you will need to replace the Oven control asap if possible. It has failed.
Possible causes--
*Power surge
*Failed logic(IC)
*Oven Temp Sensor failuer that has resulted in extreme temps that has overheated the board.
Posted on Jun 07, 2009
SOURCE: Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Posted on Jun 13, 2009
  • 949 Answers
SOURCE: Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
Posted on May 10, 2010
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
My kitchen aid kebc208kss0 is getting the PF error in cool down mode.
\I am not sure y it is giving the PF code because that code is saying there has been a power failure. U could be right in the direction you are thinking.
Apr 26, 2014 | KitchenAid Ovens
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    It is a free standing kitchen aid oven. I put it on quick self clean and it said it would end at 2:00. The panel went blank at 1:20 and it is past 2:00 and it is still locked. I checked the circuit br
    Unfortunately KitchenAid ovens notoriously blow a thermal fuse when you use the self cleaning cycle, and if you're lucky that's all that happened. Hopefully your oven is still under warranty. If so, call KitchenAid customer service and they will repair it for free.
    If you're handy you can check/replace the thermal fuse yourself (requires pulling out the oven and taking off the back panel, finding and replacing the fuse- be sure to turn off power and gas first).
    Nov 13, 2012 | Ovens
    We lost power to the entire home in the middle of the self cleaning cycle of the KitchenAid oven. Now the keypad control panel has gone blank and we can't get it to turn back on. Tried flipping the...
    there is a thermal fuse in the back or on top of the oven that is blown. its designed to blow if the oven gets too hot. you will have to remove the oven from the wall to check it. thats probably why kitchen aid wants to send someone out.
    Feb 03, 2011 | KitchenAid KEBC208 Electric Double Oven
    I used the cleaning feature on my kitchen aid architect series oven KEBK101 - now when you turn the oven on it does not heat up - what part do I need to replace - Kitchenaid will not address
    Yup Thermofuse stops the elements from heating after the self-cleaning cycle. You have to take out the oven, TURN OFF THE POWER at your circuit breaker, remove all the screws on the oven back panel, you'll see the thermofuse near the center (there are two 1/4" spade connectors (one leads from one leg of the power junction box). Two screws to remove it.
    Oct 27, 2009 | KitchenAid KEBC107 Electric Single Oven
    We have a Kitchen Aid double oven that is nearly a year old (builder installed.) We ran the self cleaning option on both ovens (top first) for the first time and now the lower oven no longer works. The...
    First, I would not delay in notifying your builder by phone and then follow up in writing so that you have a record that you have told him about the problem. Your stove may still be under warranty. He should be able to direct you to filing a claim. One question though, does your oven have a "Sabbath Mode" setting? If so, that could interfere with the regular operation of the oven. What style and model number is the oven?
    Jun 21, 2009 | Ovens
    Self Clean does not work
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
    KitchenAid KEBC208 Electric Double Oven Logo
    97 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
