Question about HP DeskJet 1220c InkJet Printer
HP 1220 C--ran out of yellow. Put in new cartridge. In fact tried two sets of new color and black 78 and 45 cartridges. Test prints look fine. But when I print an 8x10 photo--have tried eight or ten times. The first third or half looks mostly okay--a little weak, but by the end, all I see is green--hardly any black or red. Is this the printer? The cartridges? Suggestions?
    President:
  • 4,070 Answers
Hi! The problem will surely be on the printer head. It may have reached it's break point that when it performs a larger print outs it fails on the half. You can replace the head itself but I strongly suggest that you purchase a new one for optimum performance. Hope this helps and thank you for using FixYa!
Posted on Nov 05, 2010
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet Pro L7555 will not print black ink
Replace print head(black & yellow) or try to clean the nozzle.(try youtube videos for cleaning)
May 19, 2014 | HP OfficeJet Office Equipment & Supplies
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to...
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Feb 05, 2010 | HP Office Equipment & Supplies
My HP 640 will not print. Ran the test, no print.
If these are new cartridges, make sure you removed all of the protective plastic wrap that comes when packaged.  usually its red , yellow or orange plastic tab that should be removed.
If these are not new cartridges, you may need to try another set.
Try running the head cleaning utility under the printer utilities options HP is very good at having this utility available to trouble shoot most common problems.  If you don't have this utility, try updating your printer driver. (basically uninstall the printer and download the driver from the HP website, and reinstall the printer using the latest driver).
Hope this helps..
~enov8
Mar 07, 2009 | HP 640 Inkjet Fax Machine
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&lang=en&rule=12548&product=79477 Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=11882&lc=en&dlc=en&cc=us&lang=en&product=79477 -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP DeskJet 1220c InkJet Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
