My you tube is not working properly its very slow
  • 320 Answers
Check all your programs if they are running slow also. The problem is usually caused by a low virtual memory. You can fix it by upgrading the virtual memory into a higher value.
Posted on Nov 05, 2010
Slow computer ,you tube not working properly
Try running a registry cleaner and anti malware software to remove stuff that has crept in from the net.
Feb 26, 2014 | Computers & Internet
I have had five flats in rapid sequence. None are punctures. The first three were slow leaks but no one could find the leak. Even placed the hyperinflated tube in soapy water. Nothing. Next morning it was...
Hi. It could be you're puting in too much air. Check pressures. 2) check valve that it is tight in and sealing properly. Note: When you travel on hot pavement the pressure will rise so put the proper air in. It maybe written on tire sidewall. Max PSI ..... Good luck.
Jun 14, 2011 | Sunlite Cycling
In my samsung monte You tube, videos,songs are not running,but other application works properly
Ok , I am also use Monte and youtube is working properly. If your GPRS is slow then it will not work properly. And update your Handset.
Thanks.
May 13, 2011 | YouTube Videos
No ice....slow to refill ice tray
You need to check the water pressure coming from the water shut off to the frig. Sometimes right at the shut off debris gets in and the water comes out really slow.
if this isnt the problem then it could be one of three
water valve not opening 100% (replace)
ice maker timer is not working properly (replace)
the tube that feeds the ice maker is frozen
Mar 28, 2010 | Refrigerators
Water freezing in ice maker inlet tube
yes exactly,
follow your tube down to the water vavle you probaly have a small leak in the solonoid and it is dripping up
hard to beleive but it is
you can also turn down your freezer just a bit
but you will find the replacement water valve at the
www.appliancepartspros.com
just type in your model number
Nov 04, 2009 | Refrigerators
Changed a/c evaperator and compressor, runs about 48 degrees temp goes up when you slow down cant find screen in high side line.
Is your cooling fan working properly? Usually when going down the road, it will cool better due to more airflow over the condensor. If your cooling fans are not working properly, this will add to the effect. Is it going to like 60-65 degrees at idle, or like 55 degrees? 60-65 is cooling fans, 55 most likely normal. Would have to see what your gauges are reading to let you know for sure. The orifice tube you are looking for is in the high side A/C line near the evap core. Look for a place where the line can be undone, with dimpling to hold the tube in place.
Jun 09, 2009 | 1998 Chevrolet Cavalier
Our ice maker plus WHIRLPOOL is not working
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 28, 2009 | Refrigerators
My ice maker overflows
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut. or it could be that the ice maker is not level.
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Slow water dispener
there s a motor present for the working of the water dispenser whose rpm would be slow due to which the water dispenser is slow so change tat motor or repair it and then use it after tat it will work properly
Jul 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
LG SIDE BY SIDE - REPLACED FILTER BUT WATER VERY SLOW
You may have ice building up inside the fill tube that is slowing the water flow.  You will have to remove ice maker to see inside the tube.  If the tube has ice buildup, use a hair dryer to melt the ice.  Then is should work fine.
May 23, 2008 | LG LRSC-26922 Side by Side Refrigerator
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
