Question about Goodman PHKJ048-1 Air Conditioner
We gave a Goodmn Hertz 60 Phase I heat pump - installed this summer....worked great for cooling..now that temps are dropping we are needing heat. When we turn it on it comes on but never heats. Think it was not programmed to switch to heat....is that something we can do?
  • 4 Answers
If you changed the unit but didn't change the thermostat it is possible that the thermostat that you have will not work with that unit. I see that the unit you installed is a heat pump, you may have a straight cool T-Stat. If you put the T-Stat in the "Auto" "Heat" mode the outdoor fan and the compressor should be workng as well as the blower fan. If it turns out that the outdoor fan and compressor are not running you will want to buy a Thernostat that is compatable with heatpumps should be 2 heat/ 1 cool
Posted on Nov 06, 2010
Vp17-3 bunn o matic will not brew no water will come out if i wait about 15-20 mins it will start spitting out some water like 1/4 full! The heating elements are working on all 3 burners
You have 2 water valves on that coffee maker a water inlet and a dispense valve the warmers are only heat plates the element is inside tank Bunn has a great site for manuals it's a free download
Nov 13, 2016 | Electrical Supplies
How to get a 115/60 MZ machine in a 110/50 mZ country
Buy it in the US or Canada online and pay for shipping
Apr 11, 2015 | Kenmore Elite 45986 Front Load Washer
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
My inside and outside unit turn on fine, out side fan and compressor running good,inside blowing cool air, about four minutes after that, out side unit shutoff, no humming, nothing.
Are you heating or cooling? When the outdoor unit shuts off how does it come back on. Or are you saying that the outdoor unit is short cycling off and on
Jan 17, 2018 | Ruud Heating & Cooling
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Jun 20, 2011 | Amana PTH153B50AM Air Conditioner
Hi i looking for water pump 10hp single phase borehole 150feet under ground 1500gpm submersible please can you rang run on single-phase 240v thanks harry 00353860818018
Don't knw what your problem is but here is a page that gives you the information, normally 3 phase on single phase motor but if you can change the winding settings you might here is the page hope it helps.
http://www.pentairpool.com/pdfs/CSeriesCommercialBronzePumpOM.pdf
Dec 20, 2010 | Pentair 10hp 3ph Single Phase 220440v 60...
Cool air comes out when the heat turns on. When I switch to Em heat, warm air comes out. Over the summer the air worker great, however when I switched to heat on the thermostat, cool air came out. Why?
Check the following. 1. Your setting temp must be higher +3 than room temp. 2. Check heating sensor.3. And also heater element.(If it's reversal valve, checke RV is working)
Dec 12, 2010 | Weather King 10AJA3601AH Air Conditioner
Its a manual stop start controller with reset. push start button and strange humming noise for a short period then kicks out. could it be a capacitor
its probably the capacitor,if your lucky that is,if the motor bearings are freezing up from heat.age this repair can get expensive
Jul 26, 2010 | Pentair 5hp 1ph Single Phase 230v 60...
I HAVE 1.5TON AC IE WINDOW a\C IT CONSUMES MORE
Air conditioners compressors are high starting torque motors , although it uses 15 amps running , it takes perhaps 3 times that briefly to start a compressor. Thats why in the old days the lights dimmed while the ac started etc. Air conditioners are designed to operate at 95 outdoor/ 80 indoor. The design temps are 80 air into a 40 coil gives 60 supply temp, for a 20 temp drop with each pass.
The outdoor coils are 30 above ambient so the hot outdoor air will still be cool in relation to the hot refrigerant gas and remove heat to condense it back to a liquid. Since the pressures and temps are according to ambient there isnt any way to not have the amp draw increase with load.
That said check the breaker for age and replace if not pretty, check all connections for tightness, consider dedicated circuit.
Aug 25, 2009 | Heating & Cooling
Heating & Cooling Logo
104 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
