Question about Sony KDSR50XBR1 50" Projection HDTV
Sony KDS60R2000 Bravia SXRD Full HD - No picture after its switched on. Green light blinking but no picture. Since it was bought (new about 4 years ago) it would occasionly just "switch off" by itself and the picture would go black. After about 5 mins would switch on again and then no further problems for months.
  • 10,594 Answers
It is time for new lamp in tv as existing has reached on end of its working life.
Replace lamp in tv to fix the problem, lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Posted on Nov 05, 2010
Testimonial: "Your solution was correct !!!!! I checked the lamp and it had failed. Many thanks."
My brother has a 60" Sony xbr1 year 2006 and the red light blinks when you turn on but no picture or sound. Has a brand new bulb, that's not the issue.
Could be a cooling fan. Sometimes they don't start because of dust buildup. Could be worn out also. I had to replace mine once. Can order via internet.
Nov 14, 2014 | Sony XBR-60LX900 BRAVIA LX900 Series 60 3D...
Sony tv screen has no picture
Watch the red light and or power light when this happens, if there is a specific number of blinks and then a pause that is a error code.
May 25, 2012 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Sony Bravia SXRD KDS60R2000 won't turn on
May I know if there's a led light lit solid/blinking. If blinking, count how many times it will flash.
Oct 26, 2011 | Televison & Video
I have a sony bravia sxrd television and when it is on sometimes the screen goes blank, the power light blinks green, but there is still sound.
You have a leaky capacitor in the high voltage section of your tv and it will eventually fail completely if not replaced. This is not an expensive fix $50. ballpark
Sep 24, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a Sony Wega SXRD. First issue was the
No. Could be a bad ballast this time. That is the box that energizes the gas to produce light. Bulb has no filament.
Sep 10, 2017 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
639 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
