Question about Car Audio & Video
The clock display keeps on going back to zero
  • 48 Answers
Check your fuses,your memory,or constant power fuse might be blown
Posted on Nov 07, 2010
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Dec 14, 2014 | NEC LT280 LCD Projector
Knen,ore range model 790.74239310 clock panel light does not display the time
Does it appear momentarily when you press the clock key? If so, then you probably have the "energy-saver" feature turned on. To turn it off (so it "wastes" energy by displaying the clock all the time), press and hold that key. When you first press the key, the clock time will display... (Keep holding that key!) Then in about 7 seconds, the display will go blank.... (Keep holding that key!) Then in about 3 more seconds, the display will come back on. Now you can let go of that key, and the clock time will continue to display.
Oct 13, 2014 | Kenmore Kitchen Ranges
Clock resetting itself
Hi. There is a fuse for the dash cluster that keeps the time etc going. Chec
k this fuse is not blown. Your owners manual has the fuse details.
Mar 23, 2014 | 2003 Volkswagen Passat
Honda cbx 250 2008 Model, clocks keep resetting
Hi, Chris for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
Clock resets itself CBR Forum Enthusiast forums for Honda CBR Owners
Trip meter and clock keep resetting
https://grantward.files.wordpress.com/2010/10/honda-cbf-cbx-250-twister-workshop-manual-english-optnopw.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBX250 Twister Owner Manual
Apr 11, 2013 | 2006 Honda CBX 250 Twister
I am not sure how to set the time interval in the nap mode. It starts at 2 hours, and I can't change it.
Ok, this is the way it works, and I keep my clock radio for this feature alone. It is a 2 hour "count down" timer. It is set in 15 minute intervals. Supposed you wanted to take a 1/2 hour nap. Press the button but don't let go. As you hold your finger down the timer will start at 2 hours (2.0) and it will then go to 1.45, etc. When you get to a 1/2 hour let go and it will start counting down. If, in the process, you make a mistake, press the blue button and don't let go. Hold it down until it erases the setting and removes the NAP text from the front display. Release button. Start holding down the button again. Once again, the display will go to two hours, continue to press button, it will start counting back in 15 minute increments. Again, when it gets to 1/2 hour, quickly let the button go. As the clock counts down, you cannot see how much time is left on the clock. Press the button, quickly let go again. It will display how much of the 1/2 is left. When the clock counts down to zero, either the alarm will sound or the radio will start playing depending on what you set the alarm to do. Press the off button, that's it... (0:
Sep 01, 2011 | RCA RP3721 Clock Radio
Somehow the clock is displaying 24 hour time format. I want to get back to 12 hour format. How?
Push the mode button twice to enter the "set time" mode. Once the digital display is blinking, keep pushing "mode" until the PM display section in the upper left corner comes on. Once that happens you are back to the 12 hour clock. To set the clock, use the 1-4 buttons to set the hours and minutes.
Hope this helps.
May 11, 2010 | Sharper Image SI686 Clock Radio
Sony ICF-C211 Clock Radio started to display minutes:seconds only instead of showing hours:minutes. I guess, I might have pressed certain combinaton of buttons to start this. Unfortunately, I do not know...
might not be the solution but similar happen me and i went back into time and after awhile found reset,so jus keep trying,if not,turn off unplug for 24 hours and it should flash all zeros when plugged back in,but make sure no batteries in it,lol
Jan 16, 2010 | Sony ICF-C211 Clock Radio
Message center resets, mpg display resets to zero with miles to empty displayed. clicking sound heard when this happens upon engine start up
sounds like a bad relay, check connection at battery and at display. also display may be going bad also. when display resets do you lose preprogramed radio staitions or time on clock?
Nov 06, 2009 | 2004 Ford Taurus
Having trouble with the clock display
try holding down clock button.. when you 1st hold it down it will appear.. keep holding til it disappear.. then when it comes back on let go of button.. if clock button don't try another like + or - sign.. good luck.. mike
Jan 22, 2009 | Whirlpool RBD305PD Electric Double Oven
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
