Question about Compaq Armada M700 Notebook
Compaq amanda 1750 laptop
Did a f disk on the computter . then installed windows 98se ,can't get 256 colors out of it.ican get the 256color but when i reboot the computter itgoes back to the lowest setting everytime.yes i do apply it then hit okay before rebooting it
    Problem Solver:
  • 7 Answers
I suggest to reinstall the Vedio Drivers for your Notebook.
Posted on Jun 15, 2008
Have a Compac Armada 1700 laptop with Windows NT4.0 After reinstallation of NT4.0 i have only 16 colors on screen. Sombody know how to get 256 colors? Karl Hole Norway
hi
you have not install the Display drivers just go to below link and download the VGA drivers
http://www.laptopdrivers.net/video-drivers-for-compaq-armada-1700/
vote me if you find your solution
Oct 13, 2010 | Compaq Armada 1700 Notebook
Windows xp was installed on a compac armada 1750 was worling fine but after an hr or so it shut off and now wont boot or run windows all i get is black screen with window xp and 30 sec coutdown and......
On *********** board, there will be a battery, take that out and put it back in. if you have the OS disk. put it in. shut off computer, turn it back on press enter to boot from disk. either re format your hdd by deleting the partioned space or repair.
Apr 11, 2010 | Compaq Armada 1750 Notebook
I have just brought dell latitude e5500 laptop. i wanted to connected the hp officejet 5610 scanner to my laptop but am not able to do. please help
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab19
Jul 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Unable to change color depth...
Ok I think i found your problem. You don't need to install any drivers.
Switch your display to 256 colors To switch your display to 256 colors
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don't, follow the steps below if you want to switch the display temporarily while the game or program is running.
  1. On your desktop or on the Start menu, right-click the game or other program that you want to run in 256 colors, and then click Properties.
  2. Click the Compatibility tab.
  3. Select the Run in 256 colors check box.
  • The screen will revert to your default color quality when you close the program.
  • Try switching to 256 colors if your software program shows the wrong color or the graphics redraw slowly.
  • If your software program appears in a small window in the center of your screen, you can increase its size by changing your screen resolution temporarily. Follow the procedure above, but in step 3 select the Run in 640x480 screen resolution check box. Your screen resolution will revert to its previous resolution when you close the program.
  • The Compatibility tab is available only for programs or games located on your computer's hard disk. It is not available if the program is stored on a floppy disk, compact disk, or a network.
Please rate this if it fix your issue
May 30, 2009 | eMachines W3611 PC Desktop
I have sound driver problem & I want 256color configration.
All the sound drivers, graphics drivres for your motherboard will be there in motherboard CD.
Use that CD to install the drivers.
Feb 04, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Unable to boot, I can't installed WIN98
NTLDR is NT Loader which indicates that the hard disk originally contains an NT OS such as Windows XP. The laptop not reading the installer is possibly a CD ROM or CD disc problem. Most (but not all) NT OS would be using an NTFS type of HD format. Windows 98SE would only read and install on a FAT(32).
What perhaps you can do is to remove the HD from the laptop and using an external 2.5 interface to USB connect it to a 2nd PC and re-partition that HD as well as format it to FAT32. You can also make that HD bootable (do a Google) and copy the entire CD installer of Windows 98SE to a folder inside that HD.
Once back to the laptop, it should boot to a C: prompt, go to the folder where the Win98SE installation/setup files are located and run setup.exe.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 06, 2008 | Compaq Armada E500 Notebook
Hard disk not recognized when reinstalling xp
try formating the drive using fdisk in fat32, you can find this program in windows 98/98se and Me them try instaling windows xp
Nov 10, 2007 | Compaq Pentium 4 , 1.5 GHz (244318-B21)...
Boot up with no operating system
When the system starts, hold the F10 key and go into BIOS and set CD Rom as 1st Boot device (in Boot Order). Because most Compaq's would put the BIOS in a hidden NON-DOS partition on the hard drive, you may have to get an OEM recovery disk for that model. Because there is no BIOS to go to, the machine doesn't know it has a CD, HD or Floppy to go to. A boot floppy/CD is no help. Alternative 1: With another desktop and IDE to Laptop HD connector, FDISK (make active partition and hidden partition [5mb]), Format both, copy the cabs from WinME CD to c:\windows\options. Alternative 2: Find the COMPAQ OEM CD for that model. Since there was no exact model number Click here Please indicate whether this is helpful or not.
Oct 28, 2006 | Compaq Armada 1750 Notebook
Compaq Armada M700 Notebook Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
