Question about NetGear WNR2000 Wireless Router
What is the default logon for wgr614 - NetGear WNR2000 Wireless Router
  • 1,679 Answers
Netgear default
username = admin
password = password
Click on the link for more information : Link
Posted on Nov 05, 2010
Lost password for my netgear WGR614 Router
using a paper clip press the RESET button in the small hole on the rear of the device.
that will rset the router but you will have to tell it any special settings such as your ISP logon details and wireless setting all over again on most routers.
Some do remember the basic details
Feb 04, 2011 | Computers & Internet
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
I want to put password on my router netgear
do you have the manual, get the manual from netgear online and that will give you the default passwords and login.
select your router here: http://kb.netgear.com/app/products/family/a_id/1296
To access the router you use an internet browser and type the ip into the address bar, something like 192.168.1.1 then you logon with username and password. usually admin and admin for most routers. then in the settings you should find an option to set password
Jan 12, 2010 | NetGear WGR614 Wireless Router
Lost my network password and cant logon witrh my lAPTOP
You'll have to restore it to factory defaults then logon with the default password and re-configure it. Google the product with the model number for instructions on how to default it and the default password if you don't have the owners manual
Jan 02, 2010 | 2wire 1800HG Router (RG1800HG00)
I am trying to hook up wireless router, Desktop has cable. Do not want desktop to be wireless just laptop.
Login to http://192.168.1.1 from your desktop PC. This should bring your to a router logon config page.
The default login and password is usually "admin/admin" or "Administrator/Password" keep trying a few different login/password combos until you get in. "Caps/Lowercase"..etc.
Once you get in you can set the WEP/WPA security key for the router. Then apply the key you generate to your laptop.
Nov 22, 2009 | NetGear WGR614 Wireless Router
I cant get my passphrase # for router WGR614
Connect to your router via a LAN cable, logon to http://192.168.1.1 and use the user id and password for the router. If you don't remember the password, then you can reset the router settings by pressing the black button at the end of the router with a pin or so, so that you can use the default factory setting password written on your router.
In the "Advanced Wireless Settings" you can find the paraphrase and encryption key information, which you can modify yourself.
If you are still unable to find this information then let me know.
Oct 31, 2009 | NetGear WGR614 Router
Problem
The username in "admin" and password is "password" by default.IF you changed the password before and forgot now then have to do reset .Note:reset of the router will take it to the factory settings so pls note down the changes you have to do after reset eg wireless setting,mac spoof
Oct 09, 2009 | NetGear WGR614 Wireless Router
My old 2wire 2701hg-b router went bad and I replaced it. I had a netgear wgr614 attached to it for a second network and now i can not get the netgear to attach although all lighs appear okay Showdave
Its just locked up as it can't see your old router, 2 resolutions:
If you have have backed up your config settings for the router or you don't have any set then press and hold the reset button for 30 seconds, now let go and power the router off, now power the router off and back on again>this will reset the router back to factory defaults and you now connect back up to the router but you will have to setup your broadband logon again.
The second option is to connect the router via an ethernet cable and reset the router and it should let you connect wirelessly again.
Thanks
Sep 09, 2009 | NetGear WGR614 Wireless Router
WGR614 54Mbps
Wat ya need to do is follow the installation proceedure in the manual.. What is meant by the go here... 192.168.1.1 or sometimes it can be, 192.168.0.1, this is NOT a web site as such .. no, it is the "Door In" address, to your "Router" when you type in the address & required logon & Password,(NB: This logon & Password are NOT your internet ones.. usually it is something like ADMIN & ADMIN. (But it will tell you exactly in the documentation) of ya Routers address (192.....), this will allow you to adjust the settings required to access the internet etc. As per the instructions in the tutorial. However often there is an Install/Setup CD that usually comes with ya Router.. normally ya use the "Wisard" that helps you "Connect Up" and takes care of everything except for your ISP Logon & password. I have found you a link that will should help you with all of this... http://kbserver.netgear.com/products/WGR614v7.asp
Aug 31, 2007 | NetGear / WGR614 / 54Mbps / 802.11g /...
NetGear WNR2000 Wireless Router Logo
47 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
