Question about Maytag Neptune MDE5500AY Electric Dryer
I have a maytag atlantis and it doesnt turn on whats wrong with it
  • Maytag Master
  • 3,053 Answers
Hello, yaya I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
My maytag atlantis dryer heats up but on any cycle the dryer doesnt run long enough to dry the clothes i have to turn it on two or more times to dry clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 21, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis dryer drum not spinning. Light works, there is a hum from the timer, belts are good, drum spins freely, thermal fuse is good. Need to know what would be wrong with the dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis washer(spinning problem)
Your problem sounds like a broken belt . Check and replace. Good Luck Friend.
Jan 25, 2018 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Moved dryer, hooked up wrong, not working now after re-hooked up
have you check outlet with a voltmeter or even checked breaker? Is your new rect' a 3 or 4 prong outlet? If you hooked up red's to black and black to reds it still should have worked. The 220 volt heating element is between the red's and blacks the 110 circuits would be between a red or black to white wire.
May 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replacing Timer on Maytag Atlantis Dryer
Call a local appliance shop and ask about it. Maytag is pretty common and available. The timer will be about 75 dollars. It could be more depending on what all you have on it. It is pretty easy to replace once you get to it. Let me know how this turns out.
Jan 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Overload
For the most part, yes this is an easy fix depending on your model number. Contact me back with your model number and I will be able to further assist you.
Apr 08, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis doesnt run
change the copasitator this tells the machine to engage the motor
Oct 24, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
