Question about Apple iPod MA446LL/A MP3 Player
Hey Thanks for your reply on the 80g ipod! but did i mention the screen is permenantly on the white and sometimes switches to apple? well i did the menu and centre button before and also tried all the apple stuff on the website. No good. It wont even go onto the music or home screen. Any other suggestions? do you need further symptoms?
  • Apple Master
  • 2,794 Answers
If you have an Apple store in your area, I would take in there and let them look at it. They do it for no charge in there.
That way if there is something going on with the connector at the bottom of the IPod they can inspect it or take the battery out of it and reset it that way if they have to.
It could be the data port on the bottom of the connector is messed up.
Posted on Jun 14, 2008
--please help. i pod 4gb silver has white screen. does not turn off i hear 2 beeps. it stays on with white screen. What do I do?
Hi leahschecter
***White Screen of Death***
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod.
Try these steps.
Reset the iPod:
1.Turn the Hold switch on, then back to off.
2.Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
3.You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
2.Press and hold the Menu and Select buttons until the Apple logo appears
3.Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode.
If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done.
After you think it's done, wait another five minutes.
Please take time to rate Me
Bud
Nov 25, 2012 | Apple iPod MP3 Player
The screen turns on and goes white. it wont power off but it hooks up to itunes and i can put music on it but i can see anything but a white screen? what do i do??!!!
Try these steps.
Reset the iPod:
appears
of Disk Mode. If at this point you still have the white screen,
settings).
I hope this helps
Please do not forget to rate me
Thanks
May 18, 2010 | Apple iPod touch
White screen
Try these steps.
Reset the iPod:
appears
settings).
I hope this helps
Thanks
May 17, 2010 | Apple iPod MA446LL/A MP3 Player
80g ipod video. screen has ipod logo and screen
hold the select and menu buttons until the apple logo shows up, then quickly switch to holding the select and play buttons, this should put it into "disk mode." plug into itunes and click restore.
Nov 16, 2009 | Apple iPod MA446LL/A MP3 Player
I have a classic 80g hard drive ipod and one dau when I turned it on I got a white screen.
sounds like the screen has gone out on your ipod. the white screen it what happens when all of the pixels have died. you need to contact apple and see if they will replace the screen. might be might cost more than if you were to buy a new ipod. probably better off to replace the ipod.
hope this helped
please rate well.
Mar 06, 2009 | Apple iPod classic MP3 Player
White screen on my ipod 2gb nano
Hey,
there are a few possible reasons for this
1. the lcd screen is damaged.
in this case the lcd screen would need to be replaced,
check warranty and apple repairs https://selfsolve.apple.com/GetWarranty.do
2. the board or the cable between the lcd is broken or damaged.
the lcd screen would need to be replaced or the flex cable, but that might be difficult.
3. the ipod is frozen.
instructions are at
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Let me know if you need anything else.
Thanks,
Ekse
Jan 13, 2009 | Apple iPod nano
Ipod 80g problem
Hey Sader201,
If your iPod has been freezing on the Apple screen, you may wish to try resetting your iPod by doing the following:
1) Slide the "Hold" switch to "On," and then "Off" again.
2) Press and hold the "Menu" and "Select" buttons at the tame time until the Apple logo appears. This may take six to eight seconds to happen, and you may need to repeat this step.
Resetting your iPod should retain all of your music and other files, but please keep in mind that you may lose some of your customized menu settings.
If a reset does not resolve the problem, I would strongly suggest visiting Apple's support database for more information through the link I've provided below.
http://support.apple.com/kb/HT1320
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | Apple iPod classic MP3 Player
80g ipod (5th generation video) - problem with restoring and recovery mode
Do a full reset of ipod. Disconnect it and follow instructions here:
Jun 14, 2008 | Apple iPod MA446LL/A MP3 Player
80g 5th generation ipod - Keeps restoring but wont fix anything
It's not iTunes problem. It's ipod issue. Unplug ipod. Reset it:
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
