The starter will not click and light up the heater
  • 3 more comments
  • rnjkelly Nov 12, 2010
    Thanks
    Where do I find the vent pipe to check for blockages
    ray Kelly
    Hi heatman
    What I have is a Carver 3600STC gas heater in my caravan.
    I have searched the internet for info on this heater unsuccessfully.
    Can you help with this heater?
    ray k
  • rnjkelly Nov 16, 2010
    Carver 3600 STC caravan gas heater will not start - starter will not even give the usual click.
    Thanks
    Ray
  • rnjkelly Nov 21, 2010
    Hi Lyzmorato
    Sorry for the delay in getting back - have been out of town.
    The heater is a Carver 3600 STC manufactured in 1997 Serial BD681047. It is fitted to our caravan.
    Hope you can help get it started.
    Thanks
    Ray
  • rnjkelly Dec 02, 2010
    i Have sent the info for the Carver 3600 STC caravan heater. Do you have a solution yet as to how to fix it not starting?
    Regards
    ray kelly
    President:
  • 1,566 Answers
Hello there,
Can you tell me the exact model of your Air Conditioner?
Let me know so that we can assist you further.
Posted on Nov 16, 2010
  • 43,501 Answers
Many times if the ignitor will not click to light it is the pressure switch for the inducer fan....or there is something blocking the vent pipe ...
Check the vent piping for water and other blockage...even a little bit can stop it...
Check the little hoses to the pressure switch...
check for power to the ignition control and if it is getting power then replace the control...
heatman101
Posted on Nov 12, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 12, 2010
    It just occurred to me that you may be talking about a wall heater instead of a furnace....
    Those piezoelectric igniters are a once and done deal and if they stop clicking and sparking then you will have to replace it....
    The problem is that many of them are very hard to find if they are not a brand name heater...
    Try doing some searching on the internet for the ignitor and heater that you have....they are not that hard to replace if you can find the right parts...
    heatman101
  • D. Floyd Kolb
    There seems to be alot of porblems and few answers for those heaters...
    Here is the best info that I could find... I would call them...
    Good luck and hope you can get it working...
    heatman101
2007 Chrysler town and country. Battery light came on and a whirring sound came from the engine compartment.
If it's a rapid machine gun like clicking it is probably the starter motor dying. Wiggling the wire suggests an electrical earth issue. Disconnect the battery. Disconnect the starter motor wire at the engine end and rub the two faces that touch with fine sandpaper. Refit the wire and the battery.
You should also get the alternator and battery tested as the battery light and heater issues could be due to a charging or battery problem.
Jan 15, 2018 | Chrysler Cars & Trucks
99 Pontiac bonneville wont start. just get a humming. no crank or starter sound
This may be related to the antitheft security system. The system is known for turning off the starter and/or injectors when it fails. When it's the security locked out starter, you won't even hear a click when you turn the key. Is there a light on the dash that says SECURITY or a picture of a car with a lock through it? This is a common problem worth looking into. http://www.diy-gm-security.com/
Oct 06, 2016 | Pontiac Cars & Trucks
Wont start/turn over clicks when turn key/battery good
If the battery is good as you state. then the starter must be at fault, if you can reach it give it a light tap with a hammer and try again. if this fixes it you need your starter replaced or repaired.
Jan 17, 2013 | 1996 Honda Accord
My1997fordareostar van will make a clicking noise but i still have all power in battery what is the problem
A click every time you activate the starter motor generally tells us that the solenoid is working fine, but that the starter motor is faulty and requires repair/replacement.
To just double check:
Turn on the headlights when cranking.
If the lights dim significantly, then the battery doesn't have enough charge to power the starter, and the battery could require replacement.
If the lights don't dim by much, then the issue is most likely the starter motor.
Nov 12, 2012 | 1996 Ford Aerostar Extended
Car won't start just clicks. 2002 Mazda Protege5
The check eng light and the click are separate issue. The click is caused by a burned contact pad in the starter solenoid, the starter solenoid is mounted to the top of the starter motor on the engine. As for the other problem replace the O2 sensor, the heater is defective that preheats it when the engine is first started.
Jun 25, 2012 | 2002 Mazda Protege
1990 gmc sierra 4x4 starts fine 3 times then won't turn over,wait an hour or two then turns over and starts.lights and gauges activate fine when attempting to start and can hear the relays(drl and...
does the starter make a "clicking noise" when it wont turn over? check your battery cables at the battery and at the starter solenoid....if it not a connection , then it sounds like a bad starter relay/solenoid
Feb 22, 2009 | 1990 GMC Sierra
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
