Question about Panasonic SC-AK18 CD Shelf System
The 5-CD player component of my stereo reads out "Disc not read" from all 5 slots, no matter which way I load the CD. It would not accept my CD cleaner disk. The system was in unprotected storage for several years - - is it worth the money to take it in for cleaning? ssterling@neamb.com
    Master:
  • 669 Answers
There are many reasons why it fails to operate correctly. When electronics lay around for a long period of time unprotected from temperature changes and climate conditions; the interior parts tend to expand and contract; therefore become useless. If moisture invades sensitive circuit boards and electrical components, the resistance levels change and many times cause problems. Additional, heads on a CD/DVD player become coated with debris and can no longer read the data on a disc. They can be cleaned with rubbing alcohol and air dried, which may work for you. Clean it yourself and save the money.
Posted on Jan 14, 2018
3 Suggested Answers
SOURCE:
  • 130 Answers
SOURCE: CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Posted on Feb 12, 2006
silly girl
  • 513 Answers
SOURCE: CD player
Could be the classic dirty lense syndrom... If you know how to get to it, expose the laser lense, and gently brush any accumulated dust/dirt from it. There might be multiple slots, but only 1 lense. If you have a cd cleaner available you might want to try that out first, it doesn't always do the same job, but it can save you the risk of something else happening when you open it up. Good luck
Posted on Feb 13, 2006
The cd player in my car is A56820, JBL, it will load and eject cf's but not read. any fixes?
Did you get all of the CDs out of the player or are any still
stuck inside the stereo? Its the part about everything working
OK until a disc changed that makes me ask.
If a disc is jammed because it didn't load properly, you won't
be able to get all your discs out.
Oct 23, 2014 | Audio Players & Recorders
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
When I load a cd in my Stanton C324 it reads "No
Hello
Clean your CDs before and after playing them. Although the compact disc has a much longer lifespan than does something like a cassette tape, it can be more fragile. Scratches, dust or other damage to the data side of the CD will cause many CD players to fail to read the CD or cause the CD to skip.
Examine the type and format of the compact disc if your CD player fails to read it. Verify that your CD player can read the type of CD and the files contained on it. Just because you've burned a collection of songs to a CD, for example, doesn't mean that your CD player will be able to recognize that information. You must burn CDs in a specially formatted "Audio CD" mode to play them on a CD player, or your CD player must be able to recognize the MP3 file format. Some CD players have limitations on the type of CD they can read. Verify that your CD player can read CD-R, CD+R, CD-RW or CD+RW compact discs.
Update your CD player's driver, if your CD player is a drive connected to your computer. Click "Start" and select "Control Panel." Click on "Hardware and Sound" and select "Device Manager" under "Devices and Printers." Right-click the icon for your CD drive and select "Update driver software." This may solve any issues the drive was having with playing CDs.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Stanton C324 Mp3 Cd Player With Effects...
CD player doesn't work . the door to the 6 disc changer won't even open
This happens when the disc loading mechanism becomes faulty. when this happens the mechanism fails to load the disc to the right place thereby not allowing the optical lens which is supposed to read the disc to be able to read from the disc. All you have to do is get the loading motor and mechanism serviced and checked. This should get the door to the loader to start opening and in turn solve the working issue.
Hope this solution has been helpful?
Mar 05, 2011 | JVC MXKC4 360-Watt Compact Component Audio...
I have a 2005 Jeep grand cherokee...with a 6 disc cd player. It has worked fine for 3 years since i bought the vehicle...(i used burned cds in it usually) and all of a sudden it will not play or read the...
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
Jan 18, 2011 | 2005 Jeep Grand Cherokee
. DECK 1 SAYS " DISC ERROR" NO MATTER WHAT CD I
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 15, 2011 | Tascam CD-RW402 2-Disc CD Player /...
CD Player won't read disc
sounds like the cd mechanism is not completly loading, or chucking..when you tip it back the cd can move freely, need to check belts, possibly slipping
Jul 05, 2009 | Sony CD Radio Cassette Boombox, CFD-E90...
Panasonic SC-AK18 CD Shelf System Logo
42 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
