Question about Canon PIXMA MP470 All-in-One Printer
I do not have my cdrom to install on my laptop is there another was to hook it up to my laptop without it?
  • Canon Master
  • 6,487 Answers
Yes you can install this printer by downloading the printer software from this link and use that , just click HERE and proceed with the download.
Posted on Nov 05, 2010
How to fix disk controller failure 1782
Try going here http://www.hirensbootcd.org/download/ burn to disk so many useful things.. Run Mini XP
Oct 05, 2014 | HP Compaq 6710b Notebook
How can I install epson cs7400 without the cdrom
You can download and install all the necessary drivers and utilities software from this Epson support site.
Epson Stylus CX7400 All in One Printer
Sep 07, 2014 | EPSON Stylus CX7400 Series
Cdrom error
3 THINGS YOU CAN DO REDOWNLOAD/INSTALL THE DRIVERS FOR THAT SPECIFIC CDROM AGAIN .....OR IF IT WONT READ AT ALL BUY A NEW CDROM THEY MAKE THEM EXTERNAL OR INTERNAL WHATEVER FITS YOU.... OR YOU CAN GIVE IT TO A COMPUTER REPAIR MAN AND SPEND HUNDREDS BUT HE WILL ONLY TELL YOU WHAT I JUST TOLD YOU BECAUSE I AM A COMPUTER REPAIRMAN
Nov 21, 2012 | Dell Computers & Internet
Cannot boot from cdrom
your cd-rom reached its end of life, your best bet is to buy one, either online or at your local computer store.
Apr 09, 2012 | HP Compaq dc5100 Desktop PC - Intel...
How to install windows xp in lenovo G460
if you have the windows XP disc. put it inside the cdrom drive then restart the computer. keep on tapping the F12 key once the computer is restarting. you will be rprompted with boot options. select your CDrom drive as boot device then hit enter. your computer should boot now using the cdrom. XP installation should be running now.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 07, 2010 | Computers & Internet
I was installing a dvd drive, unhooked main power supply in computer, now when I turn on computer it says it needs a systems reboot disc can you help
The computer can't see the hard drive. IF the hard drive is on the same IDE ribbon as the DVD then you have a jumper problem. You need to look at the old cdrom if there was one and jumper new one the same as old one. (Master, slave or cable select) Also while you were digging around inside your computer did you pull the IDE ribbon to hard drive loose from the drive or the motherboard? Are the power connectors still hooked up? Every hard drive ribbon can have one slave and one master drive. Your hard drive should be the master and the cdrom the slave. Some systems are now set to "cable select" that means that the hard drive ribbon has a master connector and a slave connector and that the device (hard drive or cdrom) becomes a master if connected to one connector or a slave if hooked to the other one. If you go into your bios setup when you turn on the computer you should be able to look an see which of the drives or cdroms is hooked up as master or slave. Some will display this information during bootup posting.
Oct 04, 2009 | Computers & Internet
Will not find CDROM drive
you should update your BIOS. http://support.necam.com/Drivers/index.cfm?M=547
for WIN98 you want version 28.... version 30 is for win2000
Nov 14, 2008 | NEC Versa 2760MT Notebook
How to format acer aspire 5610 without cd
To format your laptop you need to insert a windows installation disc into the drive, restart the machine and before windows loads up you should see a "press anykey to boot from cdrom"
press key and follow the instructions, it will give you the option to format the laptop before it reinstalls it again.
any problems just let me know
All the best
John
Jul 27, 2008 | Acer Aspire 5610-4648 Notebook
Compaq armada e500 850mhz p3 laptop
I'd like you to get into your bios. At the main bios window make sure your bios is seeing the hard drive correctly (model number). Also check that your cdrom is listed. While in the Bios go to boot & correct the boot order. 1st should be cdrom, 2nd should be your new Hitachi.
You mentioned you connected it to a PC. Than you installed WinXP & everything went fine. Disk read error means your laptop does not like the FAT. When you bought the Hitachi did you get a disk utility? If not download it from the link provided here & test your drive. Use the disk utility to set up your new drive & format
it with the utility. Try again to boot to your cdrom & install WinXP. If your XP does not include SP1 or SP2 your drive may show a smaller size.
http://www.hitachigst.com/hdd/support/download.htm
Good luck, I hope the disk utility fixs the problem.
http://www.hitachigst.com/tech/techlib.nsf/techdocs/50C8DBC2A315A4C786256F400065B756/$file/7K100_SATA_FINAL_DS.pdf (Info)
Feb 23, 2008 | Dell Inspiron B130 Notebook
Fdc corrupted
That error message means. You must have tried to boot up to a floppy diskette. The diskette ( 's ), were made with a defective floppy drive.To re-download the Setup Disks for Floppy Boot Install of Win XP click the link below:
http://www.microsoft.com/downloads/details.aspx?familyid=E8FE6868-6E4F-471C-B455-BD5AFEE126D8&displaylang=en
Option if you have a cdrom in notebook & a real Win XP CD. Put the win xp cd in the cdrom drive. Start the Pc laptop & press the F8 key every two seconds. Windows will display a boot up option menue. Choose the cdrom. Win XP will start the installation.
Feb 11, 2008 | Computers & Internet
Canon PIXMA MP470 All-in-One Printer Logo
27 people viewed this question
Clive
Clive
old marine
old marine
