Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
My roper refridgerater is not cold enough even though the compresser fan is running and the freezer fan is running
  • 3,037 Answers
First thing to do is check for ice build up on the coils and make sure there is air flow in the unit. If there is any ice build up, then try defrosting and cleaning the coils, make sure any dust build up is also cleaned off. If that doesn't help, a new thermostat may be needed. Let me know if you need anything else.
Benjamin
Posted on Nov 05, 2010
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
My Whirlpool refridgerater on the bottm has stop getting cold, but the freezer on the top is still working perfectly. Could the amount of food in my freezer effect the temperatue of my refridgerater?
highly unlikely u usually have a duct that goes thru from the freezer to the refrigerator make sure this channel is open and not blocked or u have a fan in the refrigerator one of the 2 if u have a fan it will be behind a panel in the back of the refrigerator if u have a fan it may not be running if its not running check voltage and make sure u r getting power to the fan if so then spin the blade and make sure it spins freely if it does then u have a bad motor replace it its very simple and cheap hope this helps
Feb 27, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refridgerater-freezer model#
check relay in compressor. check if compressor is running
Feb 08, 2010 | Refrigerators
Freezer works, refrigerator doesn't, fan is working, no cold air flow from freezer to refridgerater
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
I hope that this helps you to solve your problem.
Thank you for using Fixya!!
Heatman101
Nov 25, 2009 | Whirlpool Refrigerators
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
Refridgerater
It could be the defrost thermostat located on the condenser coil on the left side of the fan in the freezer compartment... or else it could be the defrost timer located in the refrigerator behind the dome cover... defrost the freezer and make sure the drain tube is not blocked nor the air passage which blow cold air from freezer to refrigerator compartment below. Water should drip from freezer down hole into tube to an evaporator pan on the top of the compressor near the floor in the back. Make sure the tube is free flowing by pouring some hot water down it before restarting refrigerator. Rarely the defrost heating element shorts, but a simple continuity test will determine if that is o.k. Make sure the refrigerator is uplugged before checking any of these areas... there's 120 volts all about and with water and ice it can cause quite a jolt!
Oct 05, 2008 | Roper RT14DKX Top Freezer Refrigerator
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
