Question about Pantech PG-3600 Cellular Phone
What do the envlope symbols mean when they appear?
What does the >> symbols mean appearing just before the Gmail message subject
The >> before each line represent lines that have been forwarded to you ,,, in other words .. lines that were written by someone other than you...
Jul 30, 2014 | Google Gmail
Meaning of symbols little man left hand corner etc
I can't find the answer either.
Dec 28, 2012 | GPS
I have a car symbol with wrench appearing. What
It means your car is due for service, oil change, etc.
Jun 17, 2010 | 2005 Pontiac G6
A symbol appeared on my dashboard
It means that the one of your tires needs air and out of balance.
May 22, 2010 | 2005 Infiniti G35
Flashing Battery Symbol on GPX PDL805
The appearance of a battery symbol while you are using just the battery means that you are using just the battery.
That's it.
No Problem.
The flashing battery symbol is a constant reminder to you that a power intensive function is only supported by the battery, and that you should make external power available so as to complete the task without losing power in a battery drain event.
May 07, 2009 | GPX PDL805 Portable DVD Player
Flashing symbol
This symbol means that the backup battery needs to be changed. The backup battery is a button-type battery, CR1616. It is located under the main battery behind a small square panel. Instructions for changing it are in the manual -- look under "backup battery" in the index.
Apr 06, 2009 | Canon MV800i Mini DV Digital Camcorder
I have a c200 K 2002 and the symbol of the ?motor? has appeared
you have a check engine light on, you should take it to your preferred shop for diagnosis and repair
Mar 30, 2009 | 2000 Mercedes-Benz C-Class
Bad reception on my blackberry pearl.
that triangle means you have activated your roaming feature on your phone......so you should contact or visit your carrier and have them deactivate it for you.
Feb 27, 2009 | AT&T Blackberry Curve 8300 Smartphone
Unknown symbol in warning lights - 1999 VW Golf GTX
try checking the fluid levels ,brake fluid, power steering washer bottle??
Dec 08, 2008 | 1997 Volkswagen Golf
New Kodak 5300 All In one Problem
tell it a3 envlope ok a5 in settings to print envlope an dyou size ok thx nick
Feb 03, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Pantech PG-3600 Cellular Phone Logo
35 people viewed this question
Top Pantech Cell Phones Experts
Marvin
Marvin
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
