Question about Dell W4201C 42 in. Plasma HDTV
My tv starts blinking off and on to solve it i have to unplug the set wait 10 seconds and reconnect st BQCM761
  • 320 Answers
Please check if there is a programmed time schedule in the timer. Disable it to fix the problem.
Posted on Nov 05, 2010
Hi I think my Hitachi C29-F500DR TV has a fault. At first I thought someone had inadvertantly set the timer but the power indicator is not blinking 10 seconds on, 1 second off. It is blinking 3 shorts ,...
Blinking lights indicated any component failure in the TV .
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If its within warranty Please give to the company.....
OR
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
Good luck..
Jul 27, 2008 | Hitachi Televison & Video
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
My mitsubishi WD-65735 1080P has a green blinking light under the word lamp..what does that mean?
all these sets have a boot up if unplugged.
If power is lost or disconnected when reconnected green light will blink for about 70 seconds (set is rebooting) and then go off allowing set to be turned on.
Questions?
Mar 12, 2012 | Mitsubishi WD-65735 Television
10 red blinking lights on my Panasonic Plasma TV, will pause for few seconds, then blinks again. TV will not power on.
This is a power supply issue - found a company that has used power supplies, they sell them for $60.00. We recommend a professional install the board because the voltage needs to be adjusted after the install or you could damage something else. The high voltage in the set can KILL you soe be very careful. The web address for the PS board is plasmafix.com.
Jun 24, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
When i press the tv/sat button the display says unlock. How do you unlock it
Problem fixed,
I turned the unit off waited 10 seconds then turned it back on pressing the power button and set up button together this started demonstration mode.Let the demostration mode run till finished then turn it off again wait 10 seconds and turn it back on.This solved the problem
Dec 23, 2009 | Sony STR-DE545 Receiver
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
DON'T REMEBER MY USER NAME OR PASSWORD FOR SECURITY--CAN YOU HELP
You have to reset your router now. After resetting you will need to manually reconfigure the router with settings from your ISP. Resetting erases stored information like user names and passwords.
Follow this procedure to reset your router:
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified (Contact your internet service provider (ISP)). (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Hope this solves your problem.
Oct 18, 2009 | NetGear WGR614 Wireless Router
Washer stuck on Pause mode
Remove the washer from the electrical supply.
2. Remove the top panel and disconnect the wire plug to the pressure sensor.
3. Reconnect the washer to the electrical supply.
4. Press start and wait 10 seconds (washer will drop out of the continuous loop).
5. Remove the washer from the electrical supply.
6. Reconnect wire plug to pressure sensor and reinstall the top panel.
7. Reconnect the washer to the electrical supply and verify proper functionality.
8. If same symptoms occur, install a new console control.
Dec 30, 2007 | Frigidaire Affinity ATF7000EG
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Dell W4201C 42 in. Plasma HDTV Logo
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
