Question about Polaroid FLM-4201 42 in. LCD Television
I have a polaroid TLX-04240B . \r\nScreen is black. No lights in back of TV
  • 11,361 Answers
Black screen canbe caused by bad T-CON board, main board, 24vdc power supply, backlight inverter board. Please my guide get more ideas on what to look for inside.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Nov 06, 2010
I have a polaroid TLX 04240B 42
Check you power outlet for power. Check breaker pannel for bad breaker. Good luck.
Oct 30, 2012 | Polaroid Televison & Video
I have Polaroid 42" TLX-04240B
That indicates that it could have a power supply problem or a back light power problem. Some part is working when cold then failing when warm. You need to check to see if it is just the back light. With it on and after it goes dark see if you can make out a ghost like image on the screen. You will have to get quite close and near the edges to start to see any images. If you can see this and it is a moving image ie the tv i still on but just no bright display then it is your back light and most likely the back light power board. If it is actually shutting right off then it is your main power.
If it is the back light and the board is a separate piece on that model the part should be $40 to about $75 If it is the main power then you could be looking at $150 ish for a separate power module but if it is on the main board then you are talking about more money than a new tv. Both would be covered under warranty so check to see if you are covered. You can get the parts from any of several on line stores. Just do a search for Polaroid TLX repair parts. These should be cheaper than getting them from a dealer or repair depot if they are available.
Sep 01, 2011 | Televison & Video
At my Polaroid LCD TV the sound disappears for a
Go to menu reset the sound back to factory setting,should solved this problems.Not then ur Main Tuner signal board have problems.
Mar 10, 2010 | Polaroid FLM-3201 Television
Polaroid TLX-04240B going to a black screen after running for 2mins. Any ideas on how to fix this?
open the black plastic panel and the aluminum panel which has 3 screws each in the back of the tv.
look at bottom left corner of top board. to the right of the red led light,
there's these four white small switches. turn the bottom two switches to "on" and tv should be working.
It's very simple to fix the problem to everyone.
My tv capacitor was not the problem.
I hope this will help everybody.
Jan 04, 2010 | Televison & Video
I HAVE POLAROID TLX-04240B TV,HAS PICTURE STAY ON FOR AMOMENT &DI
I'm looking to purchase a broken TLX-04240B, the screen on ours is cracked. If you did not fix yours, I would be interested in purchasing it.
Sep 07, 2009 | Polaroid Televison & Video
I have a polaroid 42 inch flat screen and the screen is solid blue when i plug my cable in it is black I can here sound but no picture it is a 2007 module tlx-04240b
Make sure all the connections are correct, a "blue" screen indicates no-signal, black indicates some type of signal is getting to the tv. good luck Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Televison & Video
Polaroid tlx-04240b loses picture
I'm very appreciate to jranada's solution, my tv gets new life.
May 20, 2009 | Polaroid FLM-4201 42 in. LCD Television
My Polaroid TV model not listed, it's TLX-04240B
Can the remote do a code search? I had to do that with my Tivo remote to control my new Polaroid.
Nov 26, 2007 | Polaroid FLM-4201 42 in. LCD Television
Polaroid FLM-4201 42 in. LCD Television Logo
461 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
