Question about TechnoMarine Cruise Watch
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
  • 2,334 Answers
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Posted on Nov 06, 2010
    Problem Solver:
  • 5 Answers
My Technomarine Cruise can be running and appear not to be. The second hand only moves when the watch is in stopwatch mode. In regular time mode, the second hand does not move, presumably to save battery life.
Posted on Dec 01, 2014
MICHELE CSX HAND ALIGNMENT
You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
Oct 21, 2011 | Michele CSX Diamond watch
I was just given a black RSX 05 TechnoMarine chronograph watch, but the date is wrong. I can't seem to figure out how to fix it and I wasn't given an instruction book. How can I change the date?
your watch crown has 3 position. the normal position, the second position and the third position. pull it to the second position then turn it counter clockwise or vice versa. then push it to normal position if your done. i hope i had helped you..
Jul 10, 2011 | TechnoMarine Raft RSX05 Unisex Watch
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
I've lost the chronograph button above the winder. Where can I buy one on line and does it screw back in. Thanks. Edmond
mcdevito75, Best Bet with your Chrono watch is, check out a small watch repair shop in your area for that btton and replacement. A smaller watch repair shop may save you some money on costs.
Jun 22, 2010 | TechnoMarine Ceramique Watch TCB02C
How to reset a techomarine chronograph watch at 12:00 position
That worked well for the second hand, but did not reset the other two dials to the 12 O'clock position.
May 18, 2010 | TechnoMarine Ceramique Watch TCB02C
I have a Woman's Techno Marine CSX05-1036 watch and cannot figure out how to change the time
unscrew the crown a little so you can pull it out. this will allow you to change the date and the time. the first position is for the date and the second position is for the time.
Dec 03, 2009 | TechnoMarine Dial Chronograph Watch
How to change the hour
on most watches, you can change the hour by twisting the crown... As I can see this is a chronograph watch, mostly divers use these kinds of watches. the two other buttons are to set the chronograph. As i do not know what brand this is but, try to play with it you will find out. Or take it to a watch professional.
Jul 30, 2009 | TechnoMarine Dial Chronograph Watch
Technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Sep 27, 2008 | TechnoMarine Apnea 35mm Watch - Silver...
Watch
if it is an automatic you will have to wear it or shake it for a little while. If it is quartz then the battery might have to be changed.
Mar 29, 2007 | TechnoMarine Dial Chronograph Watch
TechnoMarine Cruise Watch Logo
632 people viewed this question
Top TechnoMarine Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
