Question about Philips Lands Phones
I have a Philips ID555 and I'm having trouble with the main handset. I can't access my phonebook/caller list - if I press the phonebook icon it shows a 'waiting' signal for a few seconds but it then beeps and returns to the main screen. If I try to open my phonebook list through the menu button the same thing happens. How do I rectify this problem? Thanks
I've just had the same problem. Just unplug the handet battery, then plug it back in again and you'll find the problem has gone away.
Posted on Nov 13, 2010
My Dect 3135 handset is flashing and shows New CID 1. How do I get rid of this and stop it flashing?
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls.
The phone saves the information for the last 50 received calls to the CID list.
The NEW icon marks any calls received since the last time you checked the list.
To open the CID list press CID.
Highlight a number and press MENU/SELECT.
The options:
Delete an entry - this will erase the number from the list.
Store Into PB - this will add the number to the phonebook.
Delete All - will erase all numbers from the list.
Jan 04, 2018 | Dect Lands Phones
Phonebook says unavailable
It is likely the phonebook is open on the other handset or base when you are accessing it from your normal handset. Take out the batteries from the other handset or turn off power to base and re-start. That should release any locked sessions or menus including the phonebook.
Aug 23, 2014 | Uniden Dect 15351 Digital Cordless Phone...
I have no idea what standby looks like; but I can't access the phonebook; I see the symbol, but nothing happens when i press it; I have successfully linked my cell and downloaded the phonebook from cell;...
A qualified person will have to remove the back (and circuit boards if necessary) to get to push buttons. Check for bits of plastic or something stuck between push button and circuit board. Check for corrosion on circuit board or missing /misaligned switch pieces.
Oct 29, 2013 | Uniden D3588-2 Corded / Cordless DECT 6.0...
I purchased a Uniden model D1688 and I don't know how to put favorites into the phonebook.
Entries can be added from the base or the handset. The CID button is on the right of the control ring; the phonebook is on the left of that ring.
If you want to add a number from the Caller ID list to the phone book, press CID and use the up/down arrows to navigate to the call that you want to add. Then press Menu/Select. Select the line Store into Pb and press Menu/Select. You will be at the Edit Name Screen for the phonebook.
To enter a new item from scratch, press the Phonebook button. Then press Menu/Select and select the Create New submenu. Press Menu/Select and enter the name of the contact using the alphabet on the key pad. (For C, press 2 three times.) Press Menu/Select and enter the phone number as it is dialed (including a 1 if needed). If you need to add a pause in the number, press Redial/Pause. However, the entire number must be less than 20 digits (including the pause). Press Menu/Select again. If you enter the number from the handset, you will be prompted to select a ringtone to always use when you get a call from that number. Press Menu/Select again. Then press End (on the handset) or Play/Stop (on the base) to exit the menu system.
Uniden has the manuals available at their site, either from the product page or the support page. All DECT phone manuals are here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manuals are listed in numerical and alphabetical order. The direct link to the D1688 manual in English is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1688-2om.pdf .
I hope this helps.
Aug 30, 2011 | Cell Phones
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
How do i copy a phone book for the Uniden DECT1560 cordless phone
Kathy,
This should do the trick!
Copying Phonebook Entries to Another Handset:
You can transfer one phonebook entry at a time or all phonebook entries at once.
1) With the phone in standby, press the address book icon.
2) To copy one entry, find the phonebook entry you want to copy, press Menu /Select , and then select Copy.
To copy all entries, press Menu /Select and then select Copy All.
3) Move the cursor to select the handset which you want to transfer the entries to and then press Menu /Select .
If you select Copy All, Are you sure? appears on the display screen. Move the cursor to select Yes, and then
4) The phonebook entries will be transferred to the designated handset. During the copy process, the receiving handset shows Receiving and the ID of the sending handset.
5) When the transfer is completed, Done! appears on the handset.
Notes: • The handsets must be currently connected to the same base.
• If the handset you want to transfer to already has seventy entries in its phonebook, you will hear a beep and Not enough memory in receiving unit appears on the display.
• If the selected handset is out of range or data transfer is cancelled, Unavailable appears in the display, Phonebook listings will not be transferred.
Have Fun!!
Jul 07, 2010 | Uniden DECT15602 Cordless Phone
EN Telephone Answering Machine ID555 Problem with Contact List
I solved my problem by switching the mains off and on. Thank You
Oct 20, 2009 | Philips Lands Phones
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Round button in middle quits working.
Sounds like you may not be selecting the right menu buttom. The soft keys are right below the screen. these three buttons function change depending on which screen you are viewing. I have copied the instructions from the manual below. You must select phonebook to view the phone book using the round button. You must select volume to change the volume with the round button.
The Standby Screen
When the phone is in standby, the handset display shows the following items:
Handset
Ringer off icon (when the ringer is off)/ day of the week and time / battery iconHandset ID and BannerNumber of new Caller ID calls received (If there are no new Caller ID messages, the Handset ID appears here.) SUN 12:00A Handset #1 New CID: 5REDIALMENU
Using the Four-way Function Key
Your handset has a four-way function key that allows you to move the cursor (or highlighted area) on the display and access the most commonly used features at the touch of a button. By moving this key to the left, you open the Phonebook. Move the key to the right to access Caller ID information. To use this four-way key, place your thumb over the key on the station and move to the four positions to get the feel of how it moves and operates.
Using the Handset Menu
To open the menu, press the MENU soft key. Highlight the option you want by pressing the four-way function key. This will move the cursor; the option currently highlighted appears in reversed out text. Select the highlighted option by pressing the OK soft key. To exit the menu and return to standby, press [].
If you do not press a key within 30 seconds, the phone will time out and exit the menu. When setting Date and Time, the time-out period is extended to two minutes.
Note: For GLOBAL SETUP and DEREGISTRATION menu options, make sure the line is not in use and the handsets are within range of the base. 123abcdefView the phonebook Four-way Function KeyUpView the Caller IDDown123abcdefView •
Jan 31, 2008 | Uniden TRU9480 Cordless Telephone
Area code
Here is a link to the site containing a pdf manual link and this is an excerpt for you :
Long Distance calls and Area Code Setting/Cancellation
While the present Caller ID information is displayed, pressing */tone/< will place
or remove the prefix "1" in the display to set the call for a long distance call, or
pressing #/> will set or cancel an area code (see page 30).
Storing Caller ID messages in the Phonebook
Messages shown in the Caller ID list can be stored in the phonebook. The phone
number and name of the party on the Caller ID list can be stored in memory.
1) When the phone is in standby mode, select the Caller ID message to be stored.
Then press the STORE soft key on the base or the EDIT soft key on the handset.
From the handset, then select E D I T ?. S t o r e / E d i t N a m e appears. If the Caller ID
message is already stored in memory, you will hear a beep and T h i s d a t a i s
a l r e a d y s t o r e d ! ! appears. The number will not be stored.
2) To complete the setting, follow the steps 3-8 in "Phonebook (Storing Phone
Numbers, Names, Distinctive Rings, and Speed Dial)" on pages 42-43.
Dec 17, 2007 | Uniden TRU8885-2 Cordless Phone
Lands Phones Logo
296 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
