Question about ASUS P4P800-X Pentium Motherboard
Motherboard problem motherboard cannot display when switch on, the cpu fan faster no beeping motherboard cannot display when switch on but indikator led motherboard is run, the cpu fan faster no beeping.why? is right...thx
  • 552 Answers
If your cpu fan is faster,it may be due to a higher frequency setting.
The frequency that it runs best at is 60 hz, but it can be running at 70 hz or higher.
Posted on Jun 14, 2008
No display. Processor fan Blower - active
Identify the pin point of device by swaping of RAM / Processor / and Board.
Then replace / repair accordingly.
Jun 02, 2011 | Asrock 775i65G Motherboard
No Beep no display: Cpu fan Running.
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Dec 29, 2010 | ASUS P4VP-MX Motherboard
Power on but no display processor fan running power switch light off
Power light possible means nothing, maybe a burned out led.
No display: Try feeling the cpu heatsink to see if its getting warm. If it is cold after 15 minutes running, the CPU may have failed. If warm, move onto the graphics. If using onboard, try using an aGP card and see if you get a display then.
(I'm assuming that you get a beep on powering up? If you get no beeps at all, confirms CPU is at fault, if 8 beeps on start up, probably graphics. any other beep codes, post them and I (or somebody else will help)
Dec 28, 2010 | PC Chips : PC-Chips M909G P4 /FSB...
I had a dell optiplex gx280. When the machine is turned on the cpu fan turn on and gets progressively faster and faster. Much faster and louder than it should to the extent that it is extremely alarming....
sounds like a PSU problem check all electrical connections that attach to your hard drive including IDE,SATA leads or simply replace them all and new PSU i would personally recomend you get a heavy duty PSU with plenty of wattage from problems that i have had you can bid and win on Ebay $30 PSU as i did
hope this helps
Jul 28, 2010 | Dell Optiplex GX280 (99301) Motherboard
Long beep when power on PC
Usually any kind of clear distinctive beep while booting up is an error code. If you get a long beep with no display then it could be the memory or CPU. Check to make sure all of your cards are pushed in all the way. Just take your hand and push on your memory, cpu, and other cards gently but firmly to make sure they are seated. Also make sure that everything is connected. You may have missed connecting power to something.
Jan 20, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
No Beep No Display
Immediately change your motherboard.
Jul 03, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Motherboard problem
Hi get the motherboard and power supply checked .
May 24, 2008 | Computers & Internet
ASUS P4P800-X Pentium Motherboard Logo
335 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
