Question about Cameras
It puts a letter s at the end of the folder name and it makes the folder into a shortcut and i cant use it
    Genius:
  • 1,177 Answers
I think you mean it does this when you drag the folder to your computer. This is a default behaviour in some situations which you can change. Do the drag and drop with the right hand mouse button instead of the left, and you will get a little dialog that asks if you want to move (no) copy (yes) or create shortcut (no). Move will do a copy but then delete the original.
Posted on Nov 05, 2010
I was assigning new products to my m202 keyboard however I accidentally assigned a product to the PLU list key. Is there any way to remedy this
Create a shortcut
Open the folder or directory that contains the program you wish to create a shortcut for.
Right-click on the program and click Create Shortcut.
This will create a shortcut named "Shortcut to <your program> in the directory you are in. If you wish to rename this shortcut, right-click the file and click rename.
Once the above steps have been completed, you can copy or cut this shortcut and paste it anywhere to execute this program.
Assign shortcut key to that Windows shortcut
Once the shortcut has been created to assign a shortcut key to that Windows shortcut follow the below steps.
Right-click the shortcut and click Properties.
Click the Shortcut tab.
Click in the Shortcut key box and press a letter. For example, if you press "p" the shortcut key will automatically be made Ctrl + Alt + P. Which means if saved when pressing Ctrland Alt and "P" all at the same time will run that shortcut.
hope this helps
Jun 07, 2012 | Computers & Internet
Tip
Shortcuts
Display the Address bar list in My Computer or Windows Explorer. F4<br />Display the shortcut menu for the selected item. SHIFT+F10<br />Display the System menu for the active window. ALT+SPACEBAR<br />Display the Start menu. CTRL+ESC<br />Display the corresponding menu. ALT+Underlined letter in a menu name<br />Carry out the corresponding command. Underlined letter in a command name on an open menu<br />Activate the menu bar in the active program. F10<br />Open the next menu to the right, or open a submenu. RIGHT ARROW<br />Open the next menu to the left, or close a submenu. LEFT ARROW<br />Refresh the active window. F5<br />View the folder one level up in My Computer or Windows Explorer. BACKSPACE<br />Cancel the current task. ESC<br />SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing
on Apr 12, 2011 | Computers & Internet
Tip
Delete An undeletable File
Open a Command Prompt window and leave it open.
Close all open programs.
Click Start, Run and enter TASKMGR.EXE
Go to the Processes tab and End Process on Explorer.exe.
Leave Task Manager open.
Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.
At the command prompt type DEL <filename> where <filename> is the file you wish to delete.
Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.
Close Task Manager.
Or you can try this
Open Notepad.exe
Click File>Save As..>
locate the folder where ur undeletable file is
Choose 'All files' from the file type box
click once on the file u wanna delete so its name appears in the 'filename' box
put a " at the start and end of the filename
(the filename should have the extension of the undeletable file so it will overwrite it)
click save,
It should ask u to overwrite the existing file, choose yes and u can delete it as normal
Here's a manual way of doing it. I'll take this off once you put into your first post zain.
1. Start
2. Run
3. Type: command
4. To move into a directory type: cd c:*** (The stars stand for your folder)
5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:progra~1kazaal~1
6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.
7. Now to delete the file type in del ***.bmp, txt, jpg, avi, etc... And if the file name has spaces you would use the special 1st 6 letters followed by a ~ and a 1 rule. Example: if your file name was bad file.bmp you would type once in the specific folder thorugh command, del badfil~1.bmp and your file should be gone. Make sure to type in the correct extension.
on Oct 09, 2010 | Computers & Internet
Unlock keypad
Create a shortcut
Shortcut Keys
Description
Alt + F
File menu options in current program.
Alt + E
Edit options in current program
F1
Universal Help in almost every Windows program.
Ctrl + A
Select all text.
Ctrl + X
Cut selected item.
Shift + Del
Cut selected item.
Ctrl + C
Copy selected item.
Ctrl + Ins
Copy selected item
Ctrl + V
Paste
Shift + Ins
Paste
Home
Goes to beginning of current line.
Ctrl + Home
Goes to beginning of document.
End
Goes to end of current line.
Ctrl + End
Goes to end of document.
Shift + Home
Highlights from current position to beginning of line.
Shift + End
Highlights from current position to end of line.
Ctrl + Left arrow
Moves one word to the left at a time.
Ctrl + Right arrow
Moves one word to the right at a time.
hope this helps
Jun 04, 2012 | Toshiba NB305-N410BL 10.1 inch Mini...
Cant play games downloaded for psp
make sure that you put the downloaded games in the GAME folder (capital letters are important) which itself is inside the PSP folder (capitals also important) so the folder you would put them in would look like F:\PSP\GAME\
All game files should end with PSP.
To play the games, from the PSP menu go to GAME then press X and scroll to select your game then press X again to confirm.
If your PSP firmware is above 1.5, it might be that you are trying to play protected games and it is why they cannot play.
Make sure you do not violate any intellectual property.
Regards,
Jan 13, 2011 | Sony PlayStation Portable (PSP) Console
Tip
Delete An "undeletable" File
Close Task Manager.
Or you can try this
Open Notepad.exe
click save,
1. Start
2. Run
3. Type: command
4. To move into a directory type: cd c:\*** (The stars stand for your folder)
5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1
on Dec 02, 2009 | Computers & Internet
Tip
Create a Shortcut or Hotkey to Eject the CD/DVD Drive
Create a Shortcut to Eject the CD/DVD Drive
Right-click on the desktop or elsewhere and choose New \ Shortcut.
In the location box, put the full path to the nircmd.exe file that you downloaded, and append the "cdrom open" command to the end of it, adjusting the drive letter to match your disc drive:
"C:\path\to\nircmd.exe" cdrom open D:
Note the location of the quotes.. if you are using a path with spaces in it, you need to make sure the quotes are only around the path to the executable, and the arguments should be placed after the quote.
Give the shortcut a meaningful name, like Eject CD or something like that, and you'll have a new icon (read below on how to use the cd-rom icon as shown)
Create a Shortcut to Close the CD/DVD Drive
You can follow the same exact instructions as above, but instead of "cdrom open" just substitute "cdrom close".
Assign a Hotkey to the Shortcut
Now that we have a shortcut, we can assign a hotkey to the shortcut by right-clicking on the icon and choosing Properties. On the Shortcut tab you'll see a place to assign the Shortcut key:
on Apr 29, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
When i click to open any folder in my usb flash drive this message appear. the item(raiiwx.exe) that short cut refers to has been changed or removed. so this shortcut will nolonger work properly
RAIIW.EXE has been seen to perform the following behavior:
  • This process creates other processes on disk
  • Injects code into other processes
RAIIW.EXE has been the subject of the following behavior:
  • Added as a Registry auto start to load Program on Boot up
  • Executed as a Process
  • Registered as a Dynamic Link Library File
  • Created as a process on disk
In short that exe you are stating is a virus or malware, I suggest scanning your system thoroughly and reformatting your flash drive.
Oct 20, 2010 | Computers & Internet
My desktop shortcuts open with search results page only
1.
Right-click Start, and then click Explore.
2.
Locate the folder, file, or program in the Folders directory, and then click the item to open it.
3.
Click the icon representing the item.
4.
Click File on the toolbar, and then Create Shortcut on the drop-down menu that appears.
5.
Right-click on the shortcut icon that is created.
6.
Choose Send To from the drop-down menu, and then click Desktop (create shortcut) on the submenu that appears.
Jan 09, 2009 | Acer Aspire™ T180 PC Desktop
My pictures
when putting pictures to favorites, it only creates a shortcut, if delete the shortcut, u still have ur photos on ur folders but if u delete those images from their original folders, the shortcuts on ur favoriotes will also be deleted so u can no longer retrieve them. best if u create a back up for ur photos on ur computer.
Sep 24, 2007 | Nokia 3650
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
