Question about Dryers
I need to replace the dryer drum on my whirlpool duet sport dryer. Would like information on the how to?
  • Steve MacDougall Nov 07, 2010
    Great link helped me step by step...and I got the job done
    Thank you somuch for the help was just what I needed. Got the project done without any issues.
  • 347 Answers
Http://www.applianceblog.com/manuals/Duetsportdryer.pdf
The above link is for a service manual that can guide you through replacing the drum on your dryer .I could explain it to you how to do it but it would take a lot of explaining without photos this is a whirlpool manual with excellent descriptions and photos on all possible repairs.The above file is fairly large and takes a few seconds to load so be patient...Hope this Helps Good Luck
Posted on Nov 06, 2010
My dryer made a loud bang and wont spin
Bridgette, Most common problem is a broken belt when dryer drum dose not turn. Look through the attached links to help diagnose and repair your dryer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Drum Not Turning
Whirlpool Dryer Drum Not Turning
Appliance Repair Forums
Duet Dryer Drum Belt part 661570 How To Replace
Jul 17, 2016 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My whirlpool duet sport dryer control panel will turn on but nothing happens after that. thecontrols change and everything but no drum rotation, no heat. and every once in a while I get the f-01 error...
you have a blown fuse if you remove the front lower cover you will see a white long fuse about 2 inch long it is bad after you put the new one on it will work but you need to keep the front off and turn on the dryer and look at the heater and see if it is lighting up red all over if not the heater needs to be replace it is shorted out and that is what made the fuse blow
Nov 02, 2012 | Whirlpool WED9371YW Duet Electric Dryer
The dryer sounds like a fifty pound weight is tumbling in it, and I see a split in the drum at the rear outside periphery and its not even tree years old yet.
you will need to take the dryer apart, and inspect the drum and if it is split then you will need to purchase a new drum or dryer:
http://shop.ebay.com/i.html?_nkw=whirlpool+dryer+drum&_frs=1&_sop=16&_trksid=p3286.c0.m359
how to open dryer:
http://www.partselect.com/dryer+remove-drum+repair.htm
you will also want to inspect the drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 25, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
How do you clean out the baffles filled with lint in the Whirlpool Duet dryer?
To remove the dryer drum baffles on a Whirlpool Duet, follow these steps:
1. UNPLUG the dryer.
2. Remove the top panel of the appliance by removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off.
3. Locate the bolts that hold the baffles in place on the outside perimeter of the drum. There should be 2 for each one.
4. Remove the screws for the baffle and it will come off.
HELPFUL HINTS:
1. Remove ONE baffle at a time so you can use the remaining baffles to turn the drum manually.
2. Drum rotates in a clockwise direction.
3. When removing or reinstalling each baffle, duct taping it place will keep it from flipping around when you get to the last bolt holding it in place. It will also keep it from dropping in the drum when removing, and help you hold it in place to reinstalling.
If you have any questions, please let me know. I hope this helps you.
Feb 07, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Duet Sport Dryer drum will not turn
Most likely thermal fuse is bad, but also could be door switch or a control problem.
Oct 12, 2017 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
How to replace whirlpool washer Drum, baffle
Just order a new one from an online parts store and put it in.  The new ones dont screw from behind.  They just snap in. By the way, the rest of the baffles will break as well. So you may as well by a couple.  But there not cheap-You can order them through Sears and pay 23.95 each.
Mar 09, 2009 | Whirlpool 8572546 Duet Sport Stacking Kit
Dryers Logo
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
