Question about Whirlpool AD50USL Dehumidifier
How much water do I put in when starting it? - Whirlpool AD50USL Dehumidifier
  • Whirlpool Master
  • 1,711 Answers
You don't put any water at all. The unit will create water from the air.
Posted on Nov 05, 2010
How much water do I put in water bucket on this thing?
You don"t put anything into the bucket. A dehumidifier will fill the bucket for you.
Jan 13, 2013 | Whirlpool AD50USL Dehumidifier
Just bought, brand new. where to put water in? unit will not turn on.
If you bought a dehumidifier, you will not need to put water in it. A dehumidifier removes water. A humidifier add moisture to the air, and you need to add water to this. Was your dehumidifier running before and then it stopped? If so, it will have a tank on the bottom that will have water in it that needs to be emptied out. Let me know if this is your problem.
Sep 27, 2010 | Aprilaire 1710 Dehumidifier
Start up instruction for dehumidifier
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
Feb 16, 2010 | Kenmore 54501 Dehumidifier
How much water to put in the water entering tray
dehumidifier's remove moisture from the air,so you really don't want water anywhere close, the tray in a dehumidifier is to collect water removed from the air. a humidifier is easy, you put a pan of water close to a heat source or moving air
Jan 31, 2010 | Dehumidifiers
Dehumidifier won't start
there should be a trip switch that is not resetting remove the bucket and find the switch. gently lift it up and try again
Aug 13, 2009 | Amana D545M Dehumidifier
Why did my dehumidifier start draining into the bucket when I put the drain hoze? Previous to putting on the hoze it was draing out the back.
Check for crub which may be blocking the drain hose. Blow the hose out by connecting it to your outside garden hose and turning on the water full force. Then reattach it to your dehumidifier.
Jun 25, 2009 | Goldstar DH304 Dehumidifier
Dehumdifier won't drain
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Sep 17, 2008 | Kenmore 54701 Dehumidifier
De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Jun 08, 2007 | LG LD65EL Dehumidifier
Danby water tank
this part is the indicator to activate the interlock that stop your deshumidifier when water tank is full. It activate a switch on the top right of the placeholder of the tank. when the switch is relaesed it tells you either thank is not there or full and light a red signal. the center of the wheel should be back the pivot. if the pivot is broken, i don't suggest you to forced the switch activated unless you use the direct drain, or you might have water spilled over a full bucket! Martin!
Aug 04, 2006 | Danby DDR451 Dehumidifier
Whirlpool AD50USL Dehumidifier Logo
76 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
