Question about Vacuums
My vacuum stopped working. If it is plugged in and not connected to the power nozzle and you turn it on nothing happens. If you plug in the power nozzle it turns and works fine but no suction.
    Novelist:
  • 147 Answers
Depending on your unit, and how old it might be, it could be the motor, wiring, or even a fuse next to or on the motor. The power is working fine you have said because the power nozzle works, but because there is no suction I am leaning towards a suction motor in this case.
Posted on Nov 05, 2010
  • skdesplinter Nov 05, 2010
    I've only had it for 7 months! It's a Kenmore Progressive 116.28614801
  • Mark Smith Nov 06, 2010
    ok in this case, it is possible that it is either a relay not connecting to the motor, or the fuse within the motor casing. Either way, it is less than the 1year manufacturer warranty. Take it back to sears there and they should be able to take care of it for you under warranty at no charge.
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Why won't power nozzle attachment turn on?
you may not have power coming from the vacuum. those plugs are known to fail.
Sep 02, 2015 | Electrolux Vacuums
The brush is not working when I turn the power on and the belt appears to be on and intact. How do I fix it?
This is actually a bad design by Bissell. Remove the Lift-Off portion of your vacuum cleaner. Down at the bottom, where the Lift-Off portion was sitting, you should see a small electrical plug part. What usually happens is this plug arc's, which causes it to burn the plug, and stop the power nozzle from spinning. If you see any black, or burning around this plug, take your vacuum back into Bissell, they will fix this, or give you a new vacuum for free. They don't even sell us their warranty stations this plug piece, you can only exchange it for a new vacuum.
If this is not burned, check the reset button for the brush, it's either located near the plug, or on the side of the brush portion of the vacuum.
I hope this was helpful to you.
Chris Jones
goVacuum.com
Jan 08, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
Power nozzle N106M on our Electrolux Guardian has stopped workin
Start simplest always and work back to most difficult... so make sure you have power to the main unit, do you have a cheap voltmeter? If not they're cheap... Second check that connection plug is not stuffed with debris. Point is isolate whether it is the unit or attachment, most likely it's in the connection and repairable by you or used vacuum repair.
Aug 04, 2017 | Electrolux Guardian Bagged Canister Vacuum
Lux legacy canister vacuum - the top light on the canister went on. No power to the bottom of the roller. What does that light mean. Looks like a plug
The "plug" light simply tells you the machine is plugged in and receiving power.
I'm not sure what you mean by "no power to the bottom of the roller". If the power nozzle motor isn't working, make sure nothing is wrapped around the brush, remove if there is, and press the reset switch.
If the power nozzle motor is running, but the brush isn't turning, then the belt must have broken, and needs to be replaced.
Considering your machine may still be under warranty, I suggest taking it to a local Aerus dealer and having it replaced.
You can find the store nearest you using the below site:
http://www.aerushome.com/shop/
Apr 27, 2010 | Electrolux Guardian Bagged Canister Vacuum
Central Vacuum works when power switch on canister is turned on, but will not turn on when connecting the hose.
DOes it not work on any of your wall inlet valves? If all wall inlets appear dead take a coin making a connection with both of the contacts inside the throat of the valve. If the vacuum turns on the problem is in your hose or the powerhead. If nothing happens plug in your hose and try wiggling the low voltage wires at the vacuum as you leave the hose plugged in with the swich on your in the "on" position ( if you have a switch) If still nothing unscrew all valve plates from wall leaving wires attatched. Inspect all connections for loose wires or wires that have come off terminals. .
Nov 09, 2009 | Kenmore Vacuums
Powerhead on rainbow not working
If the motor is NOT running - press the red button on the nozzle (assuming you have the model with the button on the nozzle)
If it stops working as soon as you release the button - you need a new circuit breaker. If Motor in the nozzle works but brush does not spin - you have to replace the belt.
Good Luck
Nov 20, 2008 | Rainbow 75th Anniversary Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
