Question about HP Computers & Internet
I have a hp Pavillion dv4 lap top that will not boot up. When I turn it on, there is power, but it does seems like the hard drive engages. I replaced the hard drive; but that did not fix the problem. I opend the back took out the memory cards and network card and inspected and took them back in; still not working. Help!
    Brigadier General:
  • 8,909 Answers
What you need to do is note the sequence that it goes through.
It should, when booting, flash the Caps Lock key and the hard drive lamp etc. When it has done that it has finished the POST as it is known, Power On Self Test. Then it should try and load from the hard drive after first going to the BIOS option. When it has finished that will then complete the boot sequence.
Try, if it gets as far as the Bios option, entering the Bios menu and set to default. If it doesn't make the Bios menu, there is a mother board fault and I cannot advise online about how to repair that.
Hope that gets you working again,
Posted on Nov 05, 2010
The hp laptops house the fan at the buttom of the unit, for those of you who use their laptops on the bed or otherwise should understand just like us the laptop needs to breathe and if it cant pull the air to cool the unit it will overheat.....Also if ur accustomed using it on the bed or if u havent given it a proper service and by that i mean pulling it apart and cleaning the fans and heatsink then u should and that will definitely solve all problems.....
rajesh700@hotmail.com
Posted on May 24, 2012
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 99 Answers
Its the motherboard.
HP made some bad choices in how they put together the dv and tx series laptops. Short version, these machines commonly cook their own motherboards due to inadequate cooling (i have one too, tx in my case).
if you are still under warranty you may be able to get this taken care of, otherwise you have a very good reason not to buy another HP notebook (this one is all done, sorry)
now if you really needed to get the machine to boot (like to salvage files from the hd) you can try these things
1 hold F10 while powering on
2 if step 1 doesn't work your laptop is now in the state I call "the lights are on but nobody is home" ie: the lights are on, the fans run, but no boot logo (hp splash screen) or bios post just a blank screen
3 take your laptop (still running as in step 2) and put it in a bag, or wrap it up in a towel or blanket.
now let it "preheat" for about 30 min.
4 power down your (now preheated) laptop do this by either holding the power button (or slider ) untill it is all the way off, or unplug and pop the battery
5 plug back in, replace battery and try booting. give it a couple tries and try holding F10 as well (i am probably just superstitious about the f10 thing but it can't hurt)
within the 1st 5 trys it should boot up.
bear in mind this is not a long term solution
Replaced power adapter but computer will not turn on.
Unplug power. Take the battery out. Press the power button. Wait a couple. Insert the power cord. See if it boots.
Dec 22, 2012 | HP Pavillion NB200UA dv4-1225dx Notebook...
My hp pavilion dv4 does not recognize my hard drive. The hard drive is not shown in the bios
Test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even the electical extensions
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Apr 28, 2012 | HP Computers & Internet
HP Pavillion dv4-1313 dx screen does not come on
SEEMS A TO BE A OS BOOT ISSUE.IF YOU HAD THE INSTALLATION CD JUST DO A BOOT WITH CD AND MAKE A REPAIR.
Apr 21, 2012 | Computers & Internet
What's HP Pavillion dv4-1313 dx monitor does not come on
SEEMS THAT THE OS IS UNABLE TO BOOT.GET THE INSTALLATION CD AD BOOT THE SELECT REPAIR.
Apr 21, 2012 | HP Pavilion dv4-1140go Laptop
HP Pavillion dv4 turn on and the fan start for a second twice and then tunn off After around 5 seconds a few leds are blinking Hard Drive work fine on other laptop What can be the reason
Hello, that sounds a motherboard problem...
Try to do this first :
1- take the battery out and disconnect from power
2- press and hold the power button at least 10 seconds
then put only the power cable not the battery and try to boot...
If this dont help...your motherboard needs to be repaired or replaced.
Thanks.Please rate this answer
Jan 25, 2011 | HP Pavilion dv4-1120us Notebook
Booting problem with my hp pavillion dv6000
it seems there is a problem with detection of hard disk drive.
as soon as you turn on the laptop press F1 key to enter the BIOS and check there to see if the hard drive is detected or not. If F1 doesnt take you into BIOS try F2.
Feb 04, 2010 | Toshiba Satellite A55-S1063 Notebook
I turn on my lap top HP Pavillion 2000 and all i get is the lights on the top of the keyboard and the screen remains BLACK, it was working fine last nite. I dont know what to do.
Pull out the battery and try to boot it on AC power only, if it boots up turn it back off reinsert the battery and try to boot again, if it does not boot then they maybe a problem with the battery.
Regards
Jul 14, 2009 | IBM ThinkPad T23 Notebook
Computers & Internet Logo
191 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
