Question about Canon PIXMA MP600 all-In-One InkJet Printer
MP600 MFP was working fine then recently can't be found as a USB device. Tried changing cable and USB port on the (DELL) computer and it makes no difference.
  • dpcrane Nov 06, 2010
    Thanks for your replies but managed to sort it out. I think what had happened is that a Windows update had been applied that broke the Cannon driver (I use a Windows 7 machine but originally bought the printer when I had an XP machine). I applied the most up to date drivers from Cannon and it all burst into life - I had convinced myself that the printer's USB card had failed!
    Guru:
  • Canon Master
  • 452 Answers
Hi;
look at the USB connector located on the printer is it broken ?
light it with a torch look inside the 4 pins are they fine ?
Posted on Nov 05, 2010
  • dpcrane Nov 05, 2010
    Thanks for the suggestion but no the pins look OK.
  • polytek Nov 05, 2010
    go to the spooler and restart it it can be blocked with antivirus programs
How do i get my computer to see my 1350 garmin nuvi?
The problem could be the computer's USB port or the cable. Make sure that you aren't connecting to a USB hub or a dock. Try a different USB A to mini-USB cable (match the number of pins and shape of the mini USB connector). Try installing the Garmin Agent software manually from http://www.garmin.com/agent .
Make sure that the Nuvi 1350 is fully charged. Disconnect the USB cable from the computer and turn off the Nuvi. Then turn it back on. Reconnect the cable to the computer at a different USB port. (If you are using a front port, try one of the back ports. Do not just switch to a top or bottom port since every pair of ports share a controller.) If you are using Windows, check if the Nuvi is listed as a mass storage device (press the Windows key + E or double-left click on the My Computer (Computer) icon). Recent security changes prevent USB devices from triggering the Auto-play feature on Windows. (You can change this from the Control Panel in the Hardware section for AutoPlay.)
Next try using a different computer if you can. If the Garmin Nuvi correctly communicates with the second machine, you may want to check the USB controller. Go to the Device Manager (from the Control Panel under Hardware) and expand the Universal Serial Bus controllers. You can remove the driver or check for updates. (Check for updates manually from the computer manufacturer as well.) Reboot the computer and check if the ports work. Check if other USB devices work on those ports. USB ports can fail. Sometimes, you might notice a device getting hot while connected to a failing port. Other times, the port just isn't getting enough power. Check if the power supply is sufficient for the number of devices both inside (hard drives, video card, etc.) and externally connected to the computer.
I hope this helps.
Oct 17, 2014 | Garmin nuvi 1350 Car GPS Receiver
I have a Dell Inspiron B130 computer and a Dell Photo AIO printer 966. Recently I could not get my computer to print on the printer. It had worked up to this point. I uninstalled the printer driver and...
First check the "Device Manager", for any USB Driver "errors".
There are 3 USB ports for your Laptop, check all the ports.
If you are using XP on your laptop, is your service packs up to date? For USB 2.0 port to function properly you got have to update a least Service Pack 2 for Win XP.
1. Have you check your USB port? Just plug in any USB devices eg. Flash drive, external HDD... and see whether the port detect the USB devices.
2. Is the USB cable for the Printer faulty? Try a new USB cable.
Hope it helps.
Nov 11, 2010 | Dell Computers & Internet
Computer says there is no communication with the printer
Couple of things to consider and try,,,have you tried another USB device in the computer, like a flash drive? If it can read the flash drive ok then the problem is not the USB port. Try using a different USB cable for the printer. Make sure your computer is up to date with the most current drivers. To me it sounds like a bad printer cable. Another thing to try is having the printer attached and when the error message comes up try wiggling the cable to see if communication is restored. If so then chances are that the printer cable is bad. Hope this helps.
Jul 22, 2010 | Dell Photo 964 All-In-One InkJet Printer
Won't print...say's the printer is not-connected.
Try a new USB cable and switching the cable to a different USB port on the laptop. Check if a known working device will work on the laptop. Make sure that you aren't getting a low power situation (low battery, battery not charging properly). If the power adapter is unplugged, see what happens when the computer is attached to the adapter and getting power from the socket.
USB ports can be shut down for power savings so double check that your computer isn't doing this. (This is an advanced portion of the power savings settings and can be found via the Screen Saver Panel in Windows.)
Check the computer's hardware (Windows Device Manager) to check that the USB ports haven't been disabled by a driver problem or any other issue. Control Panel, Device Manager and scroll down to the USB device controller (Windows)
(the most common problem is the USB cable causing an issue.)
Apr 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp600 stopped connecting to computer
try to transfer the usb cable to another USB port..or swap with the another working USB port..and restart your computer..
May 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Problem with USB cable
Have you tried connecting it to another USB port?
Sep 19, 2008 | Dell PowerEdge 2600 Server
MP600 canon printer computer cannot recognise USB device
Try different USB ports on the computer to see if its a porblem with the port connection and if there's no change there then try using another USB cable that you know is working perfectly fine.
Nov 25, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
81 people viewed this question
old marine
old marine
