Question about Vacuums
How do i thread a bobbin on a jones 451 sewing machine
reddevil6
  • 1673 Answers
SOURCE: how do get the
This is posted in the wrong area, please repost it in the correct section.
Posted on May 13, 2008
SOURCE: sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Posted on Jan 07, 2009
SOURCE: my singer 4166 sewing machine won't pick up the bo...
I had the same problem straight out of the box. I decided to buy a new machine and came across the 4166. It had more than enough functions and seemed to run smoothly. I too have problems with the bobbin not threading so I took it back into the store thinking I was doing something wrong. The saleswoman had the same problem. I was going to exchange it for another but before leaving I wanted to check to see if it worked. Again, same problem so I left without a machine. I spoke to the owner only to be told that 30% Singer machines are lemons and have to be returned for servicing because they don't work from the start. This is a waste of money and time.
The only suggestion I can offer is to either forget about the machine or take it into be serviced.
Posted on Jun 26, 2010
  • 1075 Answers
SOURCE: I have a continental electric
on the bottom bobbin if you look you will see a small metal flap this is the bobbin tentioner simply make sure the thread is under this flap ,and the top needle will do the rest.adrian.
Posted on Mar 20, 2011
wentlanv
  • 710 Answers
SOURCE: I have a New Home
Hi Madelyn,
Here is a website where you can download the ms3015 user manual: http://www.managemylife.com/mmh/owner_manuals/20778/JANOME-Mechanical-Sewing-L0905091?brand_name_search=Janome+new+home+ms3015
I hope this helps. If it does, I'd appreciate your 4 thumbs up vote. Thanks,
Handie Andie
Posted on Apr 17, 2011
I got this for my daughter in law. The machine bunches thread up underneath material. I have tried moving the upper tension, rethreaded (with pressor foot up) the needle & bobbin. I have changed...
the tension at bobbin seems to be the problem, make sure bobbin thread is in placed in bobbin CORRECTLY...then it should not be loose but loose enough to pull out with the slightest pull, top tension should be set on around 4,,,,,
Feb 28, 2014 | Singer 4411 Heavy Duty Sewing Machine
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
I received singer sewing machine 2623 machine and I do not have the manual. How can I get it and how do I fill the bobbin
Singer has manuals for most of their sewing machines available at their site. For the 2623, the manual is only available as a bound copy for $15. Go to http://www.singerco.com/accessories/instruction-manuals and enter the model number then click Search.
I believe on this model, you fill the bobbin with it on the metal pin on the top right of the machine. With a metal presser foot in place, bring the thread up and around the guide that pin. Wrap the thread a few times around the bobbin. Set the lever to the bobbin winding position and begin winding. Stop and trim the excess thread from your initial wraps after it is fully caught. Then complete winding the bobbin.
(On other Singer machines, you fill the bobbin in place with the bobbin cover moved halfway open.)
I hope this helps.
Jul 08, 2011 | Singer Vacuums
Thread and bobbin both threaded properly, but bobbin thread keeps knotting. sewing at top looks great but bobbin side is just knots!! I have a Euro-pro sewing machine.
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Mar 16, 2011 | Vacuums
It dose not sew, and when it dose the bobbin tangles up and lets out too much thread
The bobbin goes into the holder in what would appear to be the wrong direction ie, the thread doubles back. If this is correct, the bobbin tension might be too low, there is a screw on the bobbin holder to set the tension.
Jan 24, 2011 | Singer Vacuums
I have the brother Ls-2000 sewing machine i threaded the top as well as the bobbin but when i try to sew the thread gets stuck and it bunches up and tangles in the bobbin. also the little bit that did sew...
adjust your tension.You probably did not wind your bobbin properly as well.Make sure you oil your machine every month or so and make sure your bobbin is seated properly before you sew.
Go slower with the pressure foot speed and use the right needle.ALWAYS test on scrap of your sewing material first!!!
I have this machine for like 2 years and can do 2-5oz cowhide and buffalo leather on it (no joke, and it works FLAWLESSLY) inside it has full steel construction,just needs regular oiling compared to pro machines and easily made a few grand $$$ with it while my pro machine is getting repaired (I don't even bother with my pro machine anymore) But you MUST oil it every month and use the RIGHT needle and adjust your tension properly
Also pull out the thread a good 6 inches from the needle and bobbin before dropping the pressure foot and sewing.
Best $70 bucks (WITH TAX) I spent hell,the leather I use costs more than the machine!
Jan 12, 2011 | Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Dec 21, 2010 | Vacuums
Sewing machine won't pick up bobbin thread
Jan 05, 2009 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
