Question about Hitachi Televison & Video
I just replaced my Hitachi T.V's lamp after the first one ran out. Now, there seems to be a blueish glow on the lft side of the screen. It is large and very noticible. is this normal because of the new lamp, or is this a problem? The last thing I want is it to permentently burn my screen. Please help.
    Scholar:
  • 131 Answers
I would have a tv service center come out and look
at.
usually if you have blue or red oval shape on the screen it is a indication . The light engine is bad. cost of light engine is 395.00 on up. Put your tv on a blank screen you will see it,
thanks doctor video since 1987
Posted on Jun 14, 2008
I have a 60vf820 hdtv. The pictures appears to have a greenish tint but not all of the time. Sometimes the screen looks dim and sometimes appears normal. I have had the tv for 4 years and replaced the lamp...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | Hitachi UltraVision 60VF820 TV
My Hitachi 50V500A has a large area where the color is turning out to red. Is this a lamp or a complete light engine replacement job?
not the lamp. hitachi knowingly had a defect with the fan not allowing enough air to cool the lamp which has burned the red color lense resulting in the red on your screen. enjoy your new brick thanks to hitachi!
Jan 09, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a 50inch DLP Hitachi that is 3 and a half years old. I replaced the bulb about 5 months ago now the blacks are blueish and it has a greenish blotch on the screen. It also leaves an image on the...
Contrary to popular belief, any display product can have "Image Retention" and even "Burn-In". This is true for Plasma, LCD, LCOS, DLP, and CRT. I do not see a model number provided, but I would bet that you have an LCD rear projection TV rather than a DLP projection TV. If this is the case, the Blueish and Greenish blotches you are seeing on the screen are the result of UV light damage. UV light will move heavily damage the Blue panel, due it's short wave length. So, bad Blue or Green (absence or Blue) is typically the the first visual indicator of a problem. Replacing the Light Engine will resolve the problem.
Mar 15, 2010 | Hitachi 43FDX01B TV
Picture doesn't fit screen on Hitachi Plasma TV
I think that is just how the settings are applied in wide screen mode a little over sized
Oct 28, 2017 | Hitachi Televison & Video
Tv screen has a red/orange glow in the middle -should be black
I have the exact same problem. I had purchased a new lamp shortly after the warranty expired and never needed to use it. I decided to install it today to see if that helped with the red glow. No difference. Someone else posted that when the TV is moved (we just moved from Canada to the US) it can misalign or damage some component. Still trying to figure out what that is...probably cost more to fix that a new TV!!!
Sep 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
The left side of the screen is blueish?
The blue or yellow haze problem in this projector is because of two factors. 1) Dust buildup inside the optics and 2) Fading colour filters used in the internal optical process.
Inside the projector the white light from the lamp is split into three distinct colours of red, green and blue. Each colour illuminates their own monochrome LCD. Those LCDs are mounted on a prism that combines the separate images and displays the result you see via the lens.
The optical process to split the light up inside the projector is fairly complex and involves many light filters and mirrors to direct the light to the appropriate lcds. Those filters and lenses accumulate dust and also fade over time due to heat and other environmental factors.
I know that sharp sells replacement filters at $100 a piece. I do not know if Hitachi sells replacements.
To remove the dust and change filters you have to take apart the projector in a fairly complex way. I do not suggest that the average user do this. Good luck!
Mar 18, 2009 | Hitachi CP-X445 LCD Projector
Very large red spot when I have no picture on the screen
yes, you probably have a bad crt, or color wheel that also would need to be replaced. You can try resetting the lamp hours, Actually, I BET YOU HAVE A BAD BALLAST
Jan 28, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Help
I see a very large red spot on my screen now. I just replaced the lamp and it seem OK. Now I get a large red spot with no indicator lights. Is there a pending problem?
Sep 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Buzzing and glowing on circuit board
That white cylinder is a capacitor and is very dangerous, you need to discharge it and replace it. Does the top seem to be bulging on it? If so, it is bad for sure and it is cheap for a new one. If it continues to buzz after replacing it, then your board has a problem. Replace capacitor before replacing lamp. The lamp still may be good
Jun 06, 2008 | Hitachi 42V715 Rear Projection Television
Hitachi ultravision 60" LCD with red glow in center
I emailed Hitachi and they sent a new light engine to my local electronics store that they do business with. All I had to pay for was the installation which was today. I did not have to pay for the part or shipping. My tv is just like new again and the red glow is gone. I did not realize how bad it had gotten. Do not call the regular customer service because they cannot or do not want to help.
Oct 17, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
107 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
