Question about Garmin nuvi 250W GPS Receiver
Unlock garmin nuvi250w
Mother passed away and she had the code to un;lock gps systyem now i cant,is says if you go back to the location were it was activated it will automatically unlock but she lived in denver and im in california any help!!!!
    Scholar:
  • 174 Answers
I think you'll have to ship it to Garmin, the pin is stored in flash rom and can't be erased by resetting it. You will need proof of purchase too. You could of course hook it up to a pc and snoop around on the flash disk, or try to update the firmware and see if that helps.
Posted on Jun 16, 2008
Unlock garmin nuvi 680
The Garmin security lock can only be unlocked or changed with the 4 digit pass code.
The pass code can only be reset by entering the original pass code or sending it to Garmin to be reset.
Contact Garmin Tech Support for assistance.
1-800-800-1020
Mar 23, 2012 | Garmin Nuvi 680 Portable GPS Automobile...
Tip
Lost PIN for Garmin Lock - Nuvi Series
I've seen many postings from users who say they have lost their PIN code.
For those of you that don't know what a PIN code is:
Garmin provides a feature called "Garmin Lock", which allows the GPS owner to assign a (4) digit numeric unlock access code or PIN to their GPS.
The PIN is designed to prevent your GPS from being used by an un-authorized user. It was also meant to be used a a deterrent to thieves, making the GPS useless if stolen.
The PIN setup can be accessed by pressing the "wrench" symbol on the main menu (Nuvi Series). Next, press the "gear" symbol and you should see a listing for Garmin Lock.
When you set up the PIN, you will be asked to enter in a (4) digit numeric code. After you enter the 4th digit, you will be asked again for the code. This is to make sure that both entries match and that verify that the PIN that you request will be the one written into memory.
Your PIN is written into non-volatile memory..... it's not a file that is accessible via USB communications between the GPS and a PC. You can't clear it by disconnecting the power or disconnecting the battery or letting the battery run down. There is no jumper or switch inside the GPS to reset it, so don't waste your time tearing the GPS apart.
Now, after you set the PIN, you will be asked to set the "secure" location. This can be anywhere.... your work location, home, local gas station, school, etc. In order to set the secure location, your antenna must be up and you have to have a satellite lock. If you don't have a lock, the "set" key will be grayed out until you acquire a lock.
The secure location is your "back-up key" in case you forget your PIN. If you have forget your pin, all you have to do is physically go to the secure location. Make sure your antenna is up and that you have a satellite lock. When you are in the secure location, your GPS will NOT ask you for the PIN when you turn it on. You'll then be able to reach the main menu and change the PIN and secure location to something else if you desire.
If you have forgot both the PIN and secure location you are out of luck. You'll have to send your unit back to Garmin to have it unlocked. Garmin may charge you for this service.
Note: If you do send the unit back to Garmin to be unlocked and you are found not to be the original owner of the GPS and it's determined to be stolen, Garmin will contact law enforcement (they're policy on this is right on their website under FAQ's).
- Jim
http://www.sharcnet-usa.com
on Oct 10, 2008 | Garmin Nuvi 660 GPS Receiver
Tip
- Jim
http:///www.sharcnet-usa.com
on Oct 10, 2008 | Garmin nuvi 350 GPS Receiver
My garmin nuvie 205w has a pass code but i dont know it how can i reset the pass code?
for your gps to unlock you must return to with-in 50 meters of the SECURITY LOCATION .....the security location is where you first set up your gps..(could be your home or office )
once there your gps will automatically unlock for you.....make sure you change the security pin number at that point since you will have access there.
other than that you would need to send your gps back to Garmin to have them unlock it.... a receipt needs to be sent as proof of ownership......
All Garmins are register once maps are opened.....so they should have your serial number in file with name
Nov 29, 2010 | Garmin nuvi 250W GPS Receiver
Lost pin code for c550 my father passed away in kansas
I'm sorry to hear about your father. Unfortunately, you have only 3 options for unlocking a PIN locked Garmin. Enter the correct PIN, take the unit back to the location at which the PIN was originally entered, or return the unit to Garmin. If you are not the owner of record, however, Garmin will not return the unit to you.
Feb 15, 2010 | Garmin StreetPilot c550 GPS Receiver
Garmin nuvi 200
I've been trawling for unanswered questions; this information may be too late for you (or perhaps it may help you resurrect a useless machine which you have put away) but it will certainly help others searching for advice with the same problem.
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it or you wouldn't be reading this).
2. Take the unit to the Security Location you chose when activating Garmin Lock: it will then unlock without the PIN code and you can then either reset the PIN or disable Garmin Lock. The Security Location should not be the owner's home address, but many owners ignore this recommendation. Many owners choose their workplace or a close friend or relatives address for this purpose.
If neither option works then your unit is useless unless you send it to Garmin with proof of purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
I hope that you manage to either fix your problem using my advice or at least can decide whether to abandon the unit and buy another.
Jun 08, 2009 | Garmin nuvi 200W GPS Receiver
My Garmin 780 asking for a unlock code
Your only options for unlocking a PIN locked Garmin are:
1 - Enter the correct PIN
2 - Take the unit to the location at which the PIN was originally entered
3 - Send the unit back to Garmin.
Mar 28, 2009 | Garmin nuvi 780 GPS
Unlock code for my garmin nuvi 350
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Jan 02, 2009 | Garmin Nuvi 350 Car GPS Receiver
My garmin is locked and i cant unlock it
My garmin is locked and i cant unlock itdoesnt work if i dont enter the right pin
Nov 21, 2008 | Garmin StreetPilot c550 GPS Receiver
PIN CODE
Jan 14, 2008 | Garmin n vi 680 GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
651 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
