Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
I have a Samsung HLP-5085W DLP TV and continue to get the circular display that shows the triangle icon with a light icon in the lower left corner just below the triangle. The projection screen remains blank. I have replaced the lamp, lamp-ballast and the color wheel to no avail. Are there any other simple fixes that I can try or should I "Bite the bullet" and call a Service Tech? Incidentally, the color wheel was bad and even had a crack in the wheel as well as noisy bearings. There is a small ribbon cable from the color wheel that plugs into the unit and I'm not 100% sure that it's plugged in completely. Could this be causing the continuing dilema? Or, if you think it's the power supply, are there any videos or tips for replacing that piece of circuitry?
3 Suggested Answers
  • 178 Answers
SOURCE: samsung dlp 5085w comes on for four minutes then
It could be one or both, but i would just try the lamp first. There has been only a few times whre i have seen both fail, the lamp can dammage the ballast. But if the lamp is striking the ballist is working to some extent, so i would not assume the ballist is bad at this point. Although if you are still having trouble after the lamp repacement then i would suspect the ballast.
Posted on Sep 02, 2009
micromatikal
  • 2777 Answers
SOURCE: I have a Samsung HLP-5085W
I suspect it is a power supply, and has been the whole time unfortunately. I am not finding any videos for how to change it out, but it is not much more difficult than doing the color wheel and lamp ballast, if you can handle those I think you can do a power supply. Just get the new part, find the old part in the TV based on the new part... and pay attention to how to take it out.. it is not much more beyond that..
I am still checking for a video walk-through for it, or a site with step by step pictures.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 08, 2010
Meaning of black box In left corner of samsung sl605
Page 17 of the manual says the black box in the left top corner is the recording mode icon. In this icon you can see what menu you have chosen in the recording mode. In the left bottom of the display is the icon for the drive mode. It tell you if you are taking single pictures continues mode or are taking 5 frames per second (max 30 frames) or taking 3 pictures and compining the three.
Nov 01, 2013 | Samsung SL605 Digital Camera
We have a Samsung HL-T6176S DLP TV I currently have no picture. When I plug the TV in after a few minutes all 3 little lights in the lower left corner of the TV flash on and off, and still no...
The "LAMP" LED light indication flashes or stay on?The tv projection lamp been inside the tv like 1 1/2 or 2 years,tv been on and watches tv like 4 or 5 hours a day?Yes,than the projection lamp life is over.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.
Oct 22, 2010 | Samsung HLT6187SAX 61" DLP HDTV
Tv turns itself off and then back on with audio only
well it might be an issue with your ballast, since it might not be sending enough voltage to the lamp or it can be sending more than it should. i recommend you pout more attention and notice if there's a clciking sound, discountdashmerchantdotcom
Jul 22, 2009 | Samsung HLP5085W 50" Rear Projection...
I have a Samsung DLP HR-R5688w (2005) that will
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Televison & Video
Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Jan 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Buzzing sound with volume off/mute samsung 6163
had this problem. it turned out to be the color wheel. i left it alone but in 1 month's time, the color wheel shattered!. replace the color wheel asap...coz it's a messwhen it breaks
Dec 28, 2008 | Samsung HLP6163W 61" Rear Projection...
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
HLP5085W
If you look in the back of your tv, you should be able to see the light from the bulb, if the bulb isn't working no light.
Oct 12, 2007 | Samsung HLP5085W 50" Rear Projection...
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
155 people viewed this question
Henry  Thomas
Henry Thomas
