Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Heater will run and light for about a minute then cuts off and smokes real bad. you can turn the power off and turn back on and it will do the same thing again
  • All-Pro Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
I have a 97 Ford Taurus I put Marvel oil in it you have been driving for 30 minutes now it runs real real bad lost power overheating and smoking
Umm...
Overheating is either a sign of a thermostat/radiator fault, a coolant leak or a leaking cylinder head gasket.
Smoking is either due to overfilling with oil, worn valve seals or worn piston rings/worn engine.
If the trouble started when you topped up with oil, drain the oil system and try a different oil.
Nov 07, 2015 | Ford Cars & Trucks
Engine runs rough
misfire 3.5L V6
those disconnects, each , will slam the PCM into limphome mode.
you need your own $9 scan tool,
pulling the sensors, only stores DTC codes. that only hide there real ones.
next time you pull a sensor, use the scan tool and reset the PCM.
clearing all codes, then drive and see what fails.
imagine a sick patient in hospital bed and you cutting lines to the person.
you cant fix cars with no scan tool and 100x that , if intermittent.
cant. (i can, but have voltmeters and such that can log data)
running good before, , all cars do that even new. they all run
what counts when its bad.
so connect the scan tool and log the sensors, and see
what DTC pops first. and see all the sensor data.
bank1 OXY sensor 1 heaters is bad. (or wires to it melted)
on some cars , if the heater shorts, it will take out other sensors
here ill look yours up in alldata.com
the heater runs off 12vdc, and the current is monitored by the PCM.
id fix this first, (after all , its bad, fix it)
P300, is all 6 misfiring, that is most likely bad fueling, too rich or way to lean.
the OXY B1S1 short will short the C436 power bus, and maybe
slam B1 full rich,
C436 runs many other things that need power, so if it shorts.
all bets OFF !! all black-yellow wire power feeds.
it runs PCM pin E1, ,EGR, fuel press.reg.sol. , intake air bypass #1 and 2. and screws up altternator pin1 (96 only)
yah, B1S1 , new, and if wires burnt there , fixed.
Feb 04, 2014 | Acura TL Cars & Trucks
Hayward pool heater smoke
Is it smoke? Could it be steam?
If so, condensation "Rain in the inside of your new heater". This is a real problem & needs to be checked out by a Certified Heater Technical service man. Preferrably, not the one who installed.
Nov 22, 2013 | Pool & Spa
Coleman heater 3500a820 lots of smoke and now only blower works no heat
I am not sure about the heater type, but likely the heater element controller shorted out or the heater elements shorted - hence the black around where the wires go into the electric box. If you're lucky, the wires shorted to the side of the box. With the power off, open up the electrical box, mark which wires go where, remove them from the board, remove the wires from the electric box, then using electrical tape, tape up the exposed ends of the wires. Spread them out so they do not touch each other. Turn on the 60 amp breaker - if it trips, then your wires are bad and need replaced. If it does not trip, then the problem is with the heater. Do not let anyone near the wires when testing them! Don't forget to turn off the breaker if it does not trip. Again, turn off the breaker if it did not trip.
Oct 18, 2012 | Coleman Heating & Cooling
WATER KEEP RUNNING OUT OF THE RELEASE VALE
you can go to get another relief valve because if its dripping its probably bad. if you have a clark supply center nearby, you can get one there! or another plumbing place or water heater supply. you may have to drain out some water to bring the level below the valve. Shut off the power to water heater. If electric, turn gas to pilot setting, if a gas water heater. Cut off water supply to water heater as well. It is not necessary to drain the entire tank. Open a hot water faucet, drain water from tank, drain for approximately three to five minutes. Prepare the new relief valve with Teflon tape. Unscrew the relief valve counter-clockwise with a wrench to remove.
Turn the water supply back on to water heater. Make sure water is running from the open faucet before turning the power back on. good-day!
Mar 28, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
When driving my 1996 gmc jimmy today, the heater was on and smoke started coming from the vents of the heater system. we turned off the heater and smoke kept coming out and was turning the windshield ...
Your heater core is leaking. if it was left disconnected the engine coolant would have come out immediately upon starting the engine the very first time..
Jan 11, 2011 | 1996 GMC Jimmy
Got an Eagle Talon es, 1994. runs and sounds good but after a few minutes of running, it starts smoking real bad. what could be the problem? white smoke
white smoke is usually an indication of water in the engine you may have a bad head gasket or cracked block or water is building up in your muffler or tailpipe
Aug 28, 2009 | 1994 Eagle Talon
My car run find for about 15 minutes that smoke
if the smoke smells sweet your heater core is leaking is the water level going down if it is replace heater core
Aug 15, 2009 | 2002 Chrysler Concorde
Fipped over
This is a search and find type of problem. Check all wiring, especially if the generator has a low oil cut off switch. Check the wiring to that. Also, check carburetor linkage and for any springs that may have come off. Check the linkage to the governor on the engine to make sure the linkage is not binding.
Aug 08, 2009 | Coleman Powermate Premium Plus 6250W...
Smoke problem
hey
there are couple of smoke type.blue smoke is oil, black smoke is fuel, and white smoke is water, if it clears after starting and running a few minutes it's probably your valve guide seals leaking oil down on top of your pistons, causing it to smoke until burned off and foul your plugs.
Jun 28, 2008 | Peugeot Liberte Cars & Trucks
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
131 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
T bone 1963
Craig Butler
Craig Butler
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
