Question about Northern Industrial Tools Northern Industrial Portable Vertical Air Compressor 21-Gallon
I have an older Northern Tool Air Compressor model 192000, 2.5 hp. I have broken a part for it and can't find a replacement so far in the hardware stores nearby (nearest Northern Tool is 75 miles). I don't know the part name for sure. On the Pressure Reducer unit there is a small part with a 1/4" female attachment that screws onto the pressure reducer. On the other end of this piece is a male attachment to which hose snap attachment is affixed. This piece has a red handle that moves 180 degrees, opening or closing the air pressure. Could you assist me with the name for this part, and also with where I could find a replacement. The male end of mine snapped off when I inadvertently grabbed onto it when trying to move the unit which was stuck under a bench. Thanks for any assistance you can offer. Brent Lane
    President:
  • Northern Ind... Master
  • 1,388 Answers
This part is called a ball valve. To verify search ebay for the following ~ air ball valve 1/4
This part may be sold at Lowes or home depot. Good Luck
Posted on Nov 05, 2010
GASKETS FOR VALVE PLATE WHO IS MFG ?
contact Northern Tool,scroll down the page and you will see parts offered as well as a phone number
FREE SHIPPING NorthStar Air Compressor Pump 2 Stage 3 Cylinder 14 9 CFM 90...
May 04, 2016 | Northstar Air Compressor Pump 569cc, 22.9...
Supply tub to tank
That is really not a hard part to find. You should be able to remove the broken one and take the whole tube into a hardware store and they can replace it for you. It should be a copper tubing with flare nuts on the ends. If not please post the model number of the compressor
Apr 27, 2013 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
Looking for the part no. for the Ingersoll Rand mod. RA250E20, presure switch
The pressure switch part no. is 97264550. Where can you buy parts for this model? I need a valve plate.
Aug 26, 2010 | Northern Tool Air Pressure Switch For...
My compressor will not operate, I have had it for about 8 months and it has worked fine until now. I have tried several outlets and nothing. I think it is a fuse, but not sure, where is the fuse located on...
Often there is a button on the motor, usually on the back that isa thermsl breaker reset. There usually is NOT a fuse.
Other failures are defective plugs/cord/connections. Failure of pressure switch.
Nov 27, 2009 | Northern Tool Air Tools & Compressors
Compressor with head unloaders. Do I use a check valve with unloader port or a switch with a unloader on it?
Honestly you can use either. Some compressors come with both. My personal preference is the head mounted unloader valve because it's far more reliable and a lot less complicated.
However if you use a switch mounted unloader valve you can connect the tubing to either the head or the tank check valve.
Anywhere on the backside (between the check valve to the head), of the tank check valve is fine
Nov 14, 2009 | Northern Industrial 2 Hp 6 Gallons...
Need connecting rod for Sanborn type ''143'' air compressor pump
if you cant find the part ,just get a new compressor that is about the same as the old one.Not a complete unit,just the compressor.Northern tools sells many types of replacement units
Dec 14, 2008 | Air Tools & Compressors
Northern Industrial Tools Northern Industrial Portable Vertical Air Compressor 21-Gallon Logo
201 people viewed this question
Top Northern Industrial Tools Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Northern Industrial Tools Air Tool and Compressor Expert? Answer questions, earn points and help others
